Trouble Shifting....
Old Aug 4, 2005 | 06:11 PM
tarheel27's Avatar
tarheel27
Cruising
Default Trouble Shifting....
'85 automatic. I'm having trouble upshifting gears, most noticeably from first to second, it doesn't go through with the shift at normal pressure of the gas pedal. I either have to let off the gas and give it a second and it will shift or jam down on the gas and "force" it to shift. Any ideas?
Old Aug 4, 2005 | 06:13 PM
Mikez40's Avatar
Mikez40
Have you checked you trans fluid to if its low?
Old Aug 5, 2005 | 03:46 AM
goldeneye_vet's Avatar
goldeneye_vet
Have you adjusted the TV cable. Get a helms manual and they have the procedure listed in there as to what to do.
Old Aug 5, 2005 | 04:21 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Since it sounds like the WOT shift is ok, assuming fluid level is up to the mark, run through the factory TV cable "adjustment" procedure. This essentially amounts to:
-depress the tang on the TV cable mounting bracket
-move the cable head back toward the mounting bracket
-depress the accelerator fully to the floor once (engine off)
-manually rotate the throttle to WOT to verify the TV cable head has been pulled to the proper position.
If this doesn't solve the part throttle shifting have a shop measure line pressures.
Old Aug 5, 2005 | 09:23 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Sounds like the vacuum line to the trans is jacked.
Larry
code5coupe
Old Aug 8, 2005 | 10:52 AM
tarheel27's Avatar
tarheel27
Cruising
Thanks guys. I've got a fixer up here and there's a lot of work to be done on it. I have plenty of more questions...you think the best way to do it is to ask 'em one by one in the forum?
Old Aug 8, 2005 | 02:45 PM
Pete K's Avatar
Pete K
Originally Posted by tarheel27
Thanks guys. I've got a fixer up here and there's a lot of work to be done on it. I have a Haynes manual, but i have to admit that i'm not the most experienced guy for the job. I have plenty of more questions...you think the best way to do it is to ask 'em one by one in the forum?
Yes
To Trouble Shifting....
