Shorty or Long Tubes?
Old Aug 4, 2005 | 09:11 PM
KNCRSR5R's Avatar
KNCRSR5R
Default Shorty or Long Tubes?
Pros and Cons....??
Time for my next mod......
Old Aug 4, 2005 | 09:36 PM
CFI-EFI's Avatar
CFI-EFI
A year would be nice. Regardless, if you can't use long tubes for some reason, don't waste your money.
RACE ON!!!
Old Aug 4, 2005 | 10:11 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
, on both counts.
Old Aug 4, 2005 | 10:16 PM
VenkmanP's Avatar
VenkmanP
If you search on "headers" you'll find a few discussions of this.
You won't find much in the way of evidence though, just opinions.
Old Aug 4, 2005 | 10:21 PM
Cherry6speed's Avatar
Cherry6speed
I would get the long tubes if you plan on building up the motor with heads and a cam. If not, wait on them, $ wise they are very expensive for the amount of power yield on a stock motor. Simply put, they will allow you to make more power whereas stock exhaust will hold you back pretty quick once you cam the car and add heads etc .
Old Aug 4, 2005 | 10:33 PM
Strick's Avatar
Strick
Here is the argument for shorties, they are easier to install as they bolt up directly to the head and OEM cats. They give you some increase in hp, about half as much as LTs (in the middle of stock and LTs as far as hp increase). They help keep the heat down under the hood (especially if ceramic coated). And they look much better than those rusty ole manifolds. But, they also can be bolted up to accept all the pollution plumbing so you can pass smog testing. If you plan on bigger things for your motor, hold off for the LTs. I've run Hooker Shorties for almost 4 years now and they have worked out just fine.
Old Aug 5, 2005 | 11:45 AM
TM-Z06's Avatar
TM-Z06
Also - in Calif (and some other smog **** states) you WILL NOT legally pass state emissions testing with Long tube headers........only short tube headers are given CARB E.O#'s
Some run long tubes, and get away with it - I don't want to chance it....so, shorties are the only way for me.
Old Aug 5, 2005 | 12:07 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Read an article that said, shorties will do nothing for you, maybe less than the stock already installed, and no use going to LT headers unless you're going to or have already done mods to your engine, save your money and use it for other projects.
Old Aug 5, 2005 | 05:00 PM
KNCRSR5R's Avatar
KNCRSR5R
93 is the model year.....Hence the 40th logo.
My plan is to add some type pf header and other exhaust mods as well. Although I would like to dive into the block....it will be no time soon.
My thinking is this.....shorties, RT Cats, and some type of muffler upgrade.
The ONLY thing I may do internal would be 1.6 rockers, and thats not really internal to speak of.
Strick......did you install your shorties? Wanna help a guy out?
Old Aug 5, 2005 | 06:10 PM
Strick's Avatar
Strick
I do all my own work. Yes I installed the shorties and replaced my fuel filter when doing it (makes it accessable). I do all my work on my KwikLift. I also used copper header gaskets and used 1" allen socket head bolts for header bolts. I work slow and enjoy it. When you put time in the equation, I don't do well. When do you want to do this? Asheville is a good 2 hours away. September is booked for me as my son is getting married. It's not hard, BUT there is one thing that has to be done to your AIR pipe coming out of the pass side header, it has to be shortened about 1". I have a guy that did mine for $40 but it was perfect. I wish I knew more about welding.
Old Aug 5, 2005 | 06:55 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I have coated SLP shorties. They were on my 93 with the 396 LT1 for a while. Then i went to DRM long tubes. Big change in sound and power, 20rwhp. The reason I went shorties initially was really thinking of where I was going to be, ie Cali etc. SO, they sit on the shelf. They are cleaner and nicer looking than the cast iron stuff. But HP maybe about 10-15 hp. Lingenfelter uses them allot for C4's/.
Old Aug 5, 2005 | 08:08 PM
CFI-EFI's Avatar
CFI-EFI
WHERE??? In the black box to the left, where the avatar goes, with the red and white checkers in it?
RACE ON!!!
Old Aug 5, 2005 | 09:24 PM
mikenfl's Avatar
mikenfl
The stock L-98 manifolds are shorty headers....sort of.
How much of a difference could aftermarket shorties really make on the seat-of-the-pants dyno? Sure the primaries are a little small (inch and a half I think), but with a stock TPI, how big do they need to be? The real cork on these engines is what's behind the manifolds. Of course, long tubes are something else again
I know this thread was really more concerned with LTx's, so
Old Aug 5, 2005 | 10:00 PM
Dan Parker '96's Avatar
Dan Parker '96
Forget shorties. Install 1.6 rockers. Easier to install... more power.
Everyone should bookmark this and do it first before "real" modifications.
Best "bolt-on" in the book.
NOTE: The above statement takes into account that you've bought the factory shop manuals and have the best "stock" running car that GM could hope to have. Cars that run like crap currently will not see the benefit of increased rocker arm ratios.
Old Aug 5, 2005 | 10:30 PM
steve40th's Avatar
steve40th
These are, in all fairness a little smaller than shorty headers from SLP or Hooker. Hooker and SLP make 1 3/4. May not seem like a big deal, but everything helps.
Old Aug 5, 2005 | 10:51 PM
flatlne's Avatar
flatlne
Call Jim at TPIS and get a set of long tubes
Old Aug 5, 2005 | 11:20 PM
Dan Parker '96
Forget longtubes.. 1.6 rockers..
You can send me a "thank you" card later.
Old Aug 7, 2005 | 09:04 AM
KNCRSR5R's Avatar
KNCRSR5R
FYI: 6spd, 3.45 gears, 76,200 miles.
You seem pretty confident in your remarks. I was thinking that I would need the better breathing before I installed the 1.6 rockers so I could maximize the the higher lift and breathing capabilitles. Thats why I was going to install the headers first.
Either way, together they will do more than alone, right?
Is your argument that I will recieve most of my increase in performance from the rockers rather than the exhaust?
And by the way.....OF COURSE MY Corvette is the best one ever made....is'nt YOURS!
Old Aug 7, 2005 | 10:23 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Together that would be a great pair of mods. See, you had it right already!
To Shorty or Long Tubes?
