Steering Affected at Throttle Reduction
Old Aug 5, 2005 | 04:23 AM
poweber's Avatar
poweber
Default Steering Affected at Throttle Reduction
I'm getting a very slight steering change when I reduce power suddenly in my wife's '84 automatic. It also has a slight "jerk" when easing into a left turn, but only when it's cold. After about 10 minutes of operation, this jerk ceases. Tires and wheels check OK. Could these be related?
Old Aug 5, 2005 | 08:41 AM
Pete K's Avatar
Pete K
Closely inspect the rear tie rod assembly. This can cause the symptoms you describe.
Old Aug 5, 2005 | 08:43 AM
Pete K's Avatar
Pete K
I mis read your origional post. If it gets better when warm, it is likely the rack.
To Steering Affected at Throttle Reduction
