87 vert...reverse lights still don't work...help needed
Old Aug 5, 2005 | 03:37 PM
87vette's Avatar
87vette
Default 87 vert...reverse lights still don't work...help needed
I posted a different thread on my vette failing NYS inspection because reverse back up lights weren't coming on and the parking brake wasn't functioning.
Well the bulbs and fuse checked out ok for the back up lights and I replaced the switch where the automatic shifter was and it still doesn't come on.
Since I took it to the dealer.. I thought it would be covered under warranty for the switch for the transmission since a new one was put in back in April. As I stated in my other thread... the dealer said the wiring would need to be replaced for the back up lights. Is this a dificult task and does anyone have a wiring diagram for this? I have 1 more week to fix these issues and I don't want to spend too much money.
Once I fix this problem then I'll move onto the parking brake issue. Thanks for the help in advance.
Old Aug 5, 2005 | 03:46 PM
Pete K's Avatar
Pete K
The wiring for this circuit is not that complicated. If the switch is ggod, and power goes thru the fuse, a wire r socket is likely cut or rotted. Time and material is all that is needed. Unfortunately, a shop will charge $60 per hr to search for it. If you can fix it yourself, grab a test light and a wiring diagram and have at it.
Old Aug 5, 2005 | 05:26 PM
87vette's Avatar
87vette
So if this is the case.. a wire socket is cut or rotted.. then will it have a domino effect on the other lights ? even if its just one ? If I remember correctly they were working fine before I got the new tranny installed.. and after all of this it just quits? I will take a look more closely and see.
Old Aug 5, 2005 | 05:30 PM
Darkmke's Avatar
Darkmke
I went through this with mine. I had the dealer check it out. It was $100 or so. They found the wire wasn't working somewhere over the tranny. I suspect it was the mouse from the front bumper...don't even get me started They said they would have to drop the tranny to get to the break. I was in a hurry so I had the dealer fix it the cheap way and they just ran an alternate wire. Things are working fine and have for about 3 years. One day (soon) when I get the tranny fixed I'll get that fixed the right way too but it worked for a patch. If your so inclined, just run a new wire yourself from the switch to the lights.
Mike
Old Aug 5, 2005 | 06:05 PM
87vette's Avatar
87vette
Well guess what... I got the circuit tester... and sure enough there is power going through the wires to the two back up lights by the license plate. I tested the wires and even tested inside the socket where the bulbs sit and they work fine. So could it be the bulb eventhough they look fine ? and the dealer didn't want to put new bulbs in so I could pass inspection ?
Old Aug 5, 2005 | 06:11 PM
Pete K's Avatar
Pete K
True story: My grandfather had no back up lights on his 2 year old Fiat. He was a terrific mechanic who rebuilt aircraft instruments for a living. After spending hrs troubleshooting his problem, it turned out to be both bulbs burnt out. They looked good but were not. Do not be afraid to swap them out.
Old Aug 5, 2005 | 06:12 PM
87vette's Avatar
87vette
But all four not working ??? Is it the domino effect ? Surely they all couldn't have blown at the same time. so just to make sure I'm doing this correctly... Hook the circuit tester to the neg terminal on the battery.. and test the area needed to be done. If the light comes on.. it means its good. Correct ?
Old Aug 5, 2005 | 06:17 PM
Pete K's Avatar
Pete K
You are probably right. I forgot about the other 2 bulbs. The likelyhood of all 4 at once is slim. I will try to dig up my wiring diagram and give more specific help.
Old Aug 5, 2005 | 06:19 PM
87vette's Avatar
87vette
Another update... the rear passenger behind the wheel light is getting power in the socket.. but the drivers side rear behind the wheel socket is not getting any power. So could that be the culprit ?
Old Aug 5, 2005 | 06:28 PM
Pete K's Avatar
Pete K
Your lights are wired in parallel , so probably not. If 1 is dead the others should work. Gives you a good starting point to check at least.
Old Aug 5, 2005 | 06:33 PM
87vette's Avatar
87vette
Ok.. I will go ahead and get 4 new bulbs anyways tonite and let me know when you are able to get that wiring diagram for me. I want to complete this tonite if possible so I can do the rear parking brakes this weekend.. and get the car inspected again before they do the " FULL" emissions inspection on the car as a penalty after 10 days. I got the air pump delete.. and I dont need any more hassle. Thanks for the help thus far.
Old Aug 5, 2005 | 09:11 PM
87vette's Avatar
87vette
Just found something else out. If you have all 4 bulbs out the sockets don't get power. If you put one bulb in say by the license plate in the rear, then the other socket gets power. The same goes for the side fender back up lights. If both are out.. no power. If one bulb in.. they both get power.
So as I was putting everything back together, I put her in reverse and nothing came on. But when I put her back in park. The lights on the side fenders came on for a quick sec then shut off. I notice if the automatic shifter is slightly above the R on the console, in between P , the lights come on only on the side fenders. I have to hold it there while I move in reverse. So what gives with the back up lights next to the license plate ?
I know the dealer doesn't want to accept responsbility for a mistake their mechanic may have made in crossing wires or something when the new tranny went in. Goes to show why they want to charge me 80 an hour to rewire the car.
WTF should I do now ? It has to be something the dealer did firsthand and only until then I realized the lights dont work. It may not have worked from the very beginning. I'm more pissed now than I ever was.
Old Aug 5, 2005 | 10:10 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
What switch did you replace? Was it the park neutral switch or the back up?It sounds like something is just simply out of adjustment.
Old Aug 5, 2005 | 10:22 PM
87vette's Avatar
87vette
I replaced the park neutral switch under the console where the automatic shifter is. That was it. The one for the tranny hasnt been touched since it should already have a brand new one installed that came with the transmission back in april. The dealer said nothing was wrong with it.
Old Aug 5, 2005 | 10:26 PM
Aggravated4life
Ok,I do not know if the P/N switch affects the back up lights but if they do,then theres a procedure to adjust it correctly.I dont have my GM manual anymore but maybe someone who does can.You just want to be sure that its adjusted correctly.From what I know,its not a simple replace and be done with it item.
Wish I still had that manual to read through again and refesh some burned out brain cells.
Old Aug 5, 2005 | 10:31 PM
87vette's Avatar
87vette
If it's not anything like the heater core job I did back in the winter which was time consuming... then I'm sure I can get it done. Just need to get to the bottom of it with so little time I have.. so I can then move onto the parking brake.. so I can pass inspection.
Old Aug 5, 2005 | 10:51 PM
Aggravated4life
NY state inspections suck...I used to live in NY for almost 28 years...I had my Vette fail because one of those expensive 3rd brake light bulbs was out and I didnt even know it.We had safety/emissions where I lived and i hated it.I know its supposed to keep safe cars on the road but sometimes the crap you go through to pass sucks.My job at the dealer,they would fail people for old wiper blades and say their tires were bad when they had at least a year left in them.Its crazy.They used to fail cars that had headlights there were off adjustment by an inch or so.
Hope you get it passed soon.I know what youre going through.Hope someone can give you better info on what to do next.Im sure it will get fixed soon.
To 87 vert...reverse lights still don't work...help needed
Old Aug 6, 2005 | 12:29 PM
87vette's Avatar
87vette
Does anyone know where the ground wire leads to from all 4 back up lights ? I have the haynes manual.. but its not very helpful eventhough it shows the wiring diagram.
Old Aug 7, 2005 | 07:59 AM
87vette's Avatar
87vette
ttt
Old Aug 7, 2005 | 08:01 AM
Pete K's Avatar
Pete K
My buddy just gave me my helms book back late late night. I will go out in the garage and grab it.
