Rear Ended
Old Aug 6, 2005 | 12:40 AM
Luna's Avatar
Luna
Navigator
Default Rear Ended
I bought my 91 Vette one year ago this month. It has always been squirrelly when changing lanes and didn't handle as well as I thought it should in curves. I'd put off alignment until I replaced the tires, waiting on good tread on all 4 corners. Tonight for whatever reason I looked at the rear tires from the top of the wheel well on each side. The left rear tire appears to extend about 3/4 inch further from the wheel well than the right. The person I purchased it from said it had only been slightly damaged on the right side.... Slight body damage only. I need some input from a few suspension experts. What can the problem and fix be?
OR....did he have a tube of K-Y in his pocket?
I almost forgot. She's an L98 running ZR-1 wheels. 17" 315/35's rear and 275/40's front.
After reading a few other threads it seems that this might be normal when running the ZR1 wheels on the L98. Any feedback from ZR1 Experts is definitely welcome.
Old Aug 6, 2005 | 02:03 AM
ffvetteman's Avatar
ffvetteman
I thought I read something about that a while ago. i noticed that on my 84 with 315/35/17 GS wheels too.
I forgot what the outcome or the reason is though.
Old Aug 6, 2005 | 02:04 AM
ffvetteman's Avatar
ffvetteman
From what I remember it was not anything seroius or not a sign that it was in an accident.
Old Aug 6, 2005 | 02:12 AM
AZC4Guy's Avatar
AZC4Guy
then again, worse case scenario.. bent frame.
Old Aug 6, 2005 | 03:55 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You're only guessing at this point; take it to an alignment shop to find out what's up. Isn't it worth $90 or so to get it aligned to correct the bad handling.
If the frame has been bent it can likely be straightened by a good shop.
Old Aug 6, 2005 | 08:21 AM
Pete K's Avatar
Pete K
The suspension pieces are all aluminum. In a minor crash the pieces almost always bend well before the frame does. Leave this to a pro as others have suggested. If frame is straight, and I bet it will be, simply remove the bent pieces and swap them out .
To Rear Ended
