L98 IAC adjustments - ???
After reading the book, and before I get started....
Anyone have any advise or tricks??
Thanks,
-jumper ALDL pins A&B, turn key to On and wait a minute or two
-remove the cable connector from the IAC and the jumper from the ALDL
-start the engine and set the idle to 450rpm
-shut off and connect the cable to the IAC
Job done
If you have an adjustable TPS you will likely need to tweak the idle adjustment too. See my site for details on IAC & TPS adjustment that works for my '88 L98.
What he said. The only other thing to add is the pintle length adjustment before it's installed. If you're not installing a new one or re-installing the old one after a cleaning, there is no adjustment.......just a re-set.
