Roller Rocker Part Numbers
Old Aug 10, 2005 | 07:17 AM
Atok's Avatar
Atok
Default Roller Rocker Part Numbers
So I'm looking for 7/16" studs, 1.6 full roller, self-aligning rockers. After browsing the cam makers' web pages I still don't have part numbers:
Comps Hi-Tech: 3/8" stud only
Comps Pro Mags: Self-aligning 3/8" stud only
Crane Gold Race: Self-aligning 3/8" stud only
Crower Stainless: No self-aligning?
GM LT4: 12557779
Am I missing something? If I want self-aligning and 7/16" studs my only choice is the GM rocker? Please help me find the correct part numbers.
Old Aug 10, 2005 | 07:45 AM
rodj's Avatar
rodj
I think you have probably got the lot.
It would appear at the level requiring 7/16 most are using guide plates
Old Aug 10, 2005 | 08:01 AM
STL94LT1's Avatar
STL94LT1
I don't think anyone makes a s/a rocker in a 7/16 stud size.
Old Aug 10, 2005 | 07:37 PM
TheCorvetteKid's Avatar
TheCorvetteKid
You may need to look under listings for big block Chevy rocker arms. I don't think that any small blocks came with that size rocker stud.
Good luck.
Old Aug 10, 2005 | 08:53 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
What year Vette????
My stock #113 heads had screw in studs with 7/16" bottoms and 3/8" tops. I installed CC ProMagnum 1.6:1 for 7/16" studs.
I thought CC recently added a self aligning ProMagnum for 7/16" studs???
Actually the price of going either way is about the same as self aligning RRs cost more than non self aligning, which offsets the extra h/w needed for the latter. And, if you are switching to 7/16" studs, it is
trivial to install hardened guide plates.
Old Aug 10, 2005 | 09:18 PM
CFI-EFI's Avatar
CFI-EFI
Good luck.
That isn't going to help, because no big blocks ever came with 1.5:1 or 1.6:1 rocker arms.
All small block heads drilled and tapped for screw in studs, are 7/16" thread, at least those that still use English measure as opposed to metric threads.
RACE ON!!!
Old Aug 10, 2005 | 10:06 PM
Atok's Avatar
Atok
I know LT4s have 7/16" studs. I also thought the LT4 rockers were self-aligning? Does the LT4 have guide plates?
Old Aug 11, 2005 | 12:08 AM
STL94LT1's Avatar
STL94LT1
LT4 rocker studs are 10 mm.
Old Aug 11, 2005 | 07:19 PM
TheCorvetteKid
I just did a search on Summit Racing's website, and all the 1.6 ratio, full-roller rocker arms for 7/16" studs that came up are not self-aligning.
I'm shocked that nobody makes a self-aligning 1.6 full-roller rocker arm for 7/16" studs!
You may have to go with the GM units on this one.
Old Aug 11, 2005 | 08:11 PM
Atok's Avatar
Atok
Yeah, same thing I found. So if I want 7/16" studs I will need to use guide plates and hardened pushrods. Maybe I'll just stick with the 3/8" studs and self-aligning to save cost, but will I over stress them with a 1.6:1 ratio?
Old Aug 11, 2005 | 08:22 PM
65Z01's Avatar
65Z01
I just checked the Comp Cams web site and indeed the ProMags do not come in self aligning for 7/16" studs.
The reason for going to 7/16" studs is to minimize stud deflection at high rpm, which would reduce valve lift.
Actually if you add up the cost of self aligning ProMags vs non self aligning plus guide plates & push rods I believe the cost is about the same.
Old Aug 12, 2005 | 12:35 AM
TheCorvetteKid
No. In fact, I (literally) just finished replacing my stock stamped steel rockers with a set of self-aligning Comp Cams 1.6 Magnum Roller Rockers (p/n 1418-16). I'm still running the stock 3/8" studs, and I don't predict that they will prove to be a problem. The stock valve springs may prove to be an issue in the next few years, but the studs should be more than capable of handling these rockers.
Old Aug 12, 2005 | 07:06 AM
Atok's Avatar
Atok
Did you notice any SOTP difference? Are the rollers quieter than the stock rockers?
Old Aug 12, 2005 | 02:48 PM
TheCorvetteKid
To be honest, I haven't run the car yet. I'm still putting it all back together - I was up past midnight last night installing the rockers. I just got home from work and I'm about to hit the garage so I can finish buttoning everything back up. With luck I should have it running later tonight (I don't really have that much left to do).
I will definitely let you know if I 'feel' any difference, and if they are any quieter than stock.
Old Aug 13, 2005 | 01:33 AM
Zix's Avatar
Zix
If you want the GM LT4 self aligning 1.6 RR's I have a friend that has a couple very low mileage sets, with studs I believe. He's been wanting to get rid of them, I can ask him what he wants for a set. Let me know!
Old Aug 13, 2005 | 08:54 AM
Atok's Avatar
Atok
Yep, I'm interested...PM sent.
Old Aug 23, 2005 | 11:15 AM
LT1-Jeep's Avatar
LT1-Jeep
Cruising
HAs anyone used the Proform aluminum rockers I see on Summit really cheap? Too good of a deal to be true?
http://store.summitracing.com/partde...=KeywordSearch
To Roller Rocker Part Numbers
