flashing SYS light?
Old Aug 11, 2005 | 11:02 AM
JJ 86's Avatar
JJ 86
Default flashing SYS light?
what causes the sys light to flash?
Old Aug 11, 2005 | 11:07 AM
tjwong's Avatar
tjwong
Did you swap out the stock radio? The other issues are something in the CCM that would cause a sys light to flash on. Installing a non stock radio will also cause it.
Old Aug 11, 2005 | 11:08 AM
JJ 86's Avatar
JJ 86
still has the factory bose radio
Old Aug 11, 2005 | 11:11 AM
JJ 86's Avatar
JJ 86
also my mpg has fallen from 17mpg to 15.5mpg in the last coulple of weeks. Could this somehow be related?
Old Aug 11, 2005 | 11:14 AM
rick lambert's Avatar
rick lambert
You're throwing a code-you need to pull the codes to diagnos it. I would suspect your 02 sensor because of the drop in mileage.
Old Aug 11, 2005 | 11:21 AM
bogus's Avatar
bogus
the SYS code has little to do with the MPG, unless there is a SES that can't flash, ie, the ECU has taken a crap.
I don't know what year you have, but check this out:
C4 Guru - Pulling CCM Codes 1992-1993
Old Aug 11, 2005 | 11:22 AM
JJ 86's Avatar
JJ 86
95 a4
Old Aug 11, 2005 | 11:24 AM
Steel Blue 91's Avatar
Steel Blue 91
Check your charging system and battery. The flashing SYS on the digital display is usually 1) aftermarket radio install, or 2) battery starting to go end of life.
Old Aug 11, 2005 | 03:03 PM
neat's Avatar
neat
+1 for battery life. My 92 flashed SYS when the battery was almost dead.
Old Aug 11, 2005 | 03:30 PM
audible's Avatar
audible
Old Aug 12, 2005 | 12:00 PM
JJ 86's Avatar
JJ 86
thanks
Old Aug 12, 2005 | 11:55 PM
Nimrod's Avatar
Nimrod
From: Willow Glen, California......................"But... Chunks is our dog!"
thanks
Except that my flashing SYS was part of a problem with the ECM not communicating with the CCM.
Check out bogus' link for pulling codes. Good stuff.
Old Aug 13, 2005 | 02:15 AM
LSUgoTIGER's Avatar
LSUgoTIGER
I had the flashing SYS with no aftermarket radio, and a 6 month old battery........turned out to be my O2 sensors
Old Aug 13, 2005 | 02:52 AM
bogus's Avatar
bogus
O2s causing the SYS to flash?
intresting.
The SYS means that something is wrong in the Central Control Module.
You see, the CCM is a traffic cop controlling information between the ECM and the EBCM.
There are a number of codes from the CCM that are not as obvious as a bad battery or aftermarket stereo. It can mean any number of internal functions - instruments, climate control, courtesy lights, etc - could be faulty.
It also allows for easier extraction of ECM and EBCM codes.
Sadly, my document does not cover 1995. But the theory is the same.
Old Aug 13, 2005 | 08:50 AM
Atok's Avatar
Atok
Only one thing causes the SYS light....the CCM has a code stored. You need to install a jumper on your ALDL connector and retrieve the code(s). Once you know the code it'll tell you why the SYS light is on. You can also reset the code using this method and in many cases it won't come back. The '95 Service Manual has the complete procedure, no special tools required.
Old Aug 13, 2005 | 01:41 PM
JJ 86's Avatar
JJ 86
I replaced the battery and so far no sys light. Hopefully that fixed it. I guess time will tell. Thanks for the help!
Old Aug 13, 2005 | 01:55 PM
Matt O's Avatar
Matt O
I had the same thing on my 93, replaced the battery three months ago and no flashing SYS light....
To flashing SYS light?
