Remove headers back to stock?
Old Aug 11, 2005 | 08:24 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default Remove headers back to stock?
I have a 94 LT-1 with hotcam and hooker longtube headers Cats eliminated and B&B Triflow 3 inch stainless steel exhausts. PCM was reprogrammed by Tom Wong by previous owner. Due to heat/header problems I am considering going back to a factory exhaust manifold... Will I be disappointed in the performance? Will I lose that much HP? Has anyone done this?
Old Aug 11, 2005 | 10:31 PM
PBnf's Avatar
PBnf
I have an L98, so my experience isn't with LT1 engines. Given that I understand that long tubes will give you 20-25 HP, so that would be what you'd lose.
Old Aug 11, 2005 | 10:36 PM
redvette6spd's Avatar
redvette6spd
I don't think you will be happy with the performance results. Explain what wrong with your headers
Old Aug 11, 2005 | 10:52 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default see this post...
http://forums.corvetteforum.com/show...65&forum_id=48
Old Aug 12, 2005 | 01:01 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I think you will be much happier getting those LTs ceramic coated, replacing the burnt boots and maybe going to shorter plugs where clearence is an issue.
To Remove headers back to stock?
