Suspension Q's - help....
Old Aug 11, 2005 | 09:39 PM
65coop's Avatar
65coop
St. Jude Donor '05
Default Suspension Q's - help....
I just removed my rear spring and found several more shims on one side vs the other - the shop that installed the rear spring and lowering bolts last spring said he had a hard time getting the car to set level (Left - Right) Could this have been the problem? one lowering bolt had at least 2" of thread used / showing and the other had about 1/8 showing...
Also, how many shims should be there (each side under clamp) and does this have any effect on the ride height?
Thanks for any suggestions
Old Aug 12, 2005 | 01:14 PM
65coop's Avatar
65coop
St. Jude Donor '05
ttt
Anyone?
Old Aug 12, 2005 | 02:11 PM
aboatguy's Avatar
aboatguy
From my helms manual
State to make note of spring spacer positioning.
Here are the 1995 codes
Coupe with FE1
A SPRING YELLOW CODE
1-14044572 ABOVE SPRING
1-14048950 BELOW SPRING
1-14044572 BELOW SPRING
B SPRING GREEN CODE
1-14048950 ABOVE SPRING
COUPE WITH FE7
1-14084056 ABOVE SPRING
2-14048950 BELOW SPRING
B SPRING GREEN CODE
CONVERTIBLE
SPRING YELLOW CODE ONLY
2-14044572 ABOVE SPRING
1-14093185 ABOVE SPRING
1-14084056 BELOW SPRING
Good luck on figuring out which shim is which.
Mike
Old Aug 12, 2005 | 02:46 PM
65coop's Avatar
65coop
St. Jude Donor '05
Now thats what I'm talking about
Thanks aboatguy
Old Aug 12, 2005 | 06:19 PM
aboatguy's Avatar
aboatguy
No problem!
Mike
To Suspension Q's - help....
