shutting down,,,,,,
Old Aug 11, 2005 | 09:48 PM
blck90vette's Avatar
blck90vette
Default shutting down,,,,,,
own a 90 auto,,34,000 miles second owner,,,,,,,,was driving today (extremely hot today, 91 but very humid ) with the a/c on, and when i arrived to where i had to go,,i shut off the a/c and i shut down, and rolled into the parking space,,,,,,car started right up when i left for the next store i was going to,,,put the a/c on,,and when i arrived there,,,i shut off the a/c and yes you guessed it,,i shut down again..(this happened when i was going about5 miles an hour on both trips),,,,,,,,anyway when i left for home, started right up,,did not use a/c and car drove perfect, even when i pulled into my driveway,,,,,,volts are fine,,oil pressure fine,,,,just seems to stall when i was slowing down to park with the a/c on and i shut it off,,,,,,any help would be appreciated,,thanks
Old Aug 12, 2005 | 07:54 AM
blck90vette
Old Aug 12, 2005 | 07:58 AM
Pete K's Avatar
Pete K
Check it for vacuum leaks, scan for codes, and a fuel pressure check. Your problem could be many things.
Old Aug 12, 2005 | 06:00 PM
blck90vette
thanks pete
To shutting down,,,,,,
