conversion to Electronic climate control
The CCM is the master computer and the remaining computers are slaves -- even the ECM is a slave of the CCM, but once the vehicle has been started, the ECM can run the vehicle stand-alone until the next engine start.
The reason the CCM needs to be aware of the C68 climate control is so it will communicate with the climate control. The C68 climate control has to know the speed of the vehicle, and how long the vehicle is at that speed, to know when it can trust the outside temperature sensor. When the vehicle is standing still, or moving slowly, the external temperature sensor can "heat soak" from the close proximity to the radiator, which could give a false reading of ambient temperature.
So, the CCM communicates to the C68 climate control the speed of the vehicle and how long the vehicle is at that speed to let the C68 climate control know when the air-flow over the outside temperature sensor can be trusted to read ambient temperature.
And, I don't think you can re-program a CCM after it accumulates 100 miles on the odometer.
Tom Piper
Frist off thanks tom piper for better explaining that part of it to me...Im just going on assembly and training manuals...It helps to talk to people who understanbd whow the system works because a lot of the time the manuals assume you already have the basic concept of whats happening..
MR Nuke>As far as the 85 conversion goes>>> IM not just converting an 85 to electric AC... Im converting the entire Dash/interior over to a 1995 setup...Its a mix of 1995 parts and 1990 parts to make it all work..Very legnthy process>>> I just did not want you to think I was adding electric AC somehow to a 1985... Once complete you will never know my car was an 85 from the look/functionality of the interior..
The C68 climate control needs to know the "true" outside temperature for more than just to display it to the driver.
The C68 climate control uses the outside temperature to decide how to position "flaps" and regulators -- so, it is instrumental to the functioning of the C68 climate control.
Tom Piper
Tom Piper
Tom Piper
Tom Piper
YEah that is my understanding as well GM training manual talks about some special equip used to program it.BUT my question is the only thing it sounded like that was locked out was the Odometer...still souned like other stuff could be changed>>But I dont know that to be fact either...the training manuals are almost useless unless your sitting in the training class able to ask questions...LOL...Both the 1990 and 1995 CCM I have are for the electric AC already..Thats why Im taking the plunge if you will..>However I do have a manual AC controller from a 1996 should I not be successfull..
Of course, I'm gonna pull the AC out of it completely anyhow to clean up the engine room, reduce weight and eliminate another pending electro-mechanical hassle.
