My '93 coupe gives me a error code 36. I recently rolled over 100K miles. I can't really afford the aftermarket solutions right now. This may sound like a dumb question, but does the stock '93 even have a distributor cap and rotor button? The engine seems to run fine. Any ideas or suggestions will be greatly appreciated.
Summit Racing sells a GM OPTI for under $400. I think it's $392 and if you want to vent it like the newer style it's about another $20 in parts. Just did my 92 so all of this stuff is still fresh in my mind.
He is cheaper then Summit... and the harness for the vacuum is under $15.00.
Depending on age, you will need a new waterpump.
And yes, new optis come complete with rotor and button. You will need to remove the cap to do the venting and will want to seal the cap to body with RTV.
There is an Ebay seller in Ga that sells them for $295.I bought one from her.To do the vent conversion I went with a 95 cap&rotor from Advance instead of trying to drill a hole.That being said my ex-mechanic screwed it up by stripping one of the cap threads so it sits in a box.I bought a Dynaspark and can powerwash my engine now.
I bought one from a seller in E bay. She calls herself Partslady : lyddu@aol.com. She was very good at selling and there was supposedly a 1 year warranty. Mi optispark only lasted 200 miles and the rotor exploded. The opti was about $350. Tried to get in contact with her but will not bother returning the calls / emails.
It seems like a tipical salesman. So just beware of this sales lady.
I will get another cap and rotor but this time will rivet the rotor metal parts. Hope this helps you too in case you change opti.
Since you are blowing up rotors, what RPM are you running?
Have you considered LTCC?
Call and email that bitch until she replies. If she does not, take her to court. She has a published warrantee, and won't honour it. I would also bitch to eBay... they are getting much more sensative about this stuff.
See if you can file a "feedback" on her, too. However, most feedbacks are for shipping and initial product quality, not warrantee claims.
