Alarm going off for no reason! help
Old Aug 12, 2005 | 11:20 PM
redvetteC4's Avatar
redvetteC4
Default Alarm going off for no reason! help
I have a '91 L98 automatic that has recently had a problem with the horn/alarm going off for no reason. It has done this over the past five days or so...going off maybe once or twice in a day. The only thing out of the ordinary that happened recently is that I took out the ECM a little over a week ago to see if my car would run with a newly acquired, used ECM. I have tried unplugging the battery to see if that reset anything but it didn't help. Any suggestions are greatly appreciated.
Old Aug 12, 2005 | 11:46 PM
MrNuke's Avatar
MrNuke
I had the same thing happen due to the crazy 100+ Heat we hd last week here in CT. my alarm kept going off every few hours..
Since the weather's been a bit milder, no mroe alarm woes.
Alarms can also be triggered by a power drain, if something is shorting out I've heard..
Old Aug 13, 2005 | 07:35 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
coupe or 'vert? If a coupe, check your hatch switch, they break easily if you slam the glass down to close it or if you use a hatch vent.
For both coupes and 'verts, check the door switches as well.
Old Aug 13, 2005 | 10:22 AM
redvetteC4's Avatar
redvetteC4
Sounds like a good idea mojo...it is a coupe.
Old Aug 13, 2005 | 11:05 PM
GS977's Avatar
GS977
i had the same problem, its your door switches. i bought 2 new ones from chevrolet and problem solved. its a common problem on corvettes as my dealer said he keeps plenty switches in stock. they were like 36.00 for both.
To Alarm going off for no reason! help
