Anyone had probs. with door locks going crazy?
Old Aug 13, 2005 | 12:03 AM
evilryu530's Avatar
evilryu530
Default Anyone had probs. with door locks going crazy?
my 1984, when i drive it, sometimes the door locks will lock and unlock by itself randomly while driving. Anyone had this problem before? and if so, how did u solve it? thanks in advance. (*note. no more horn relay/radio problem )
Old Aug 13, 2005 | 12:05 AM
Perfusion's Avatar
Perfusion
I've not had the problem personally, but I have heard of it happening, so you're not alone. Best of luck...
Old Aug 13, 2005 | 12:23 AM
FD2BLK's Avatar
FD2BLK
I had this problem on a dodge intrepid that had an after markey security system. Does your 84 have the stock system or aftermarket? If aftermarket it is probably either an intermintant short or a bad box, My problem was the box.
Old Aug 13, 2005 | 12:26 AM
mikey whipreck's Avatar
mikey whipreck
I worked on a DeLorean once, that after you locked the door, the lock solenoid would keep locking and unlocking the door until it would overheat... maybe the solenoid is dying?
Old Aug 13, 2005 | 02:48 PM
evilryu530's Avatar
evilryu530
i have the stock alarm. maybe, i'll check it out some more, thanks for the inputs...however it only happens when im driving, not when the car is off...
Old Aug 13, 2005 | 03:10 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Are your interior lights also flickering at the same time (going on/off quickly) and/or does the interior lights sometimes stay on or not go off as they should? If so, might be your door switches' electrical contacts being wet or about to die. They can also affect the alarm (on our 94 LT1 couple anyway).
On our 94, they can be replaced right through the switch hole without having to take the door apart. But watch our when you buy new ones, we went through 3-4 sets before we found ones that work most of the time (sticking or poor assembly -- GM's vendor sucks).
good luck.
Old Aug 13, 2005 | 10:15 PM
kopbet89c4's Avatar
kopbet89c4
Need more input on this one... I was just about to create a thread exactly like this. Ever since I got an Autopage alarm system installed, the doors keep on locking and unlocking when I flip the turning signals. The hazards don't do this but the turn signals do... WTF?!?! It is getting very annoying.
Old Aug 14, 2005 | 08:30 PM
Maco Shark's Avatar
Maco Shark
good luck.
Same thing with our 94, going through second set of door switches as we speak.
Old Aug 16, 2005 | 12:05 AM
evilryu530's Avatar
evilryu530
i dont think the lights are flickering, just the door locks are funny, and yea my stock alarm doesnt work either. maybe someday the corvette gods will grant my wish and fix it for me. till that day, i'll stick with corvetteforum.com....thanks for the help fellows!
ebeer salute.
Old Aug 16, 2005 | 01:43 AM
cv67's Avatar
cv67
St. Jude Donor '05
This thread needs to be added to the "Straighten me out" one.
Old Aug 16, 2005 | 01:58 PM
capkarl's Avatar
capkarl
St. Jude Donor '09,'10,'11,'12,'13,'14-'15-'16-'17-'18-'19-'20-'21
Just a note of caution.
I was parked at the Port Jefferson Ferry terminal along with our local club. When the Ferry arrived everyone went to their cars. Mine would not unlock (I had the only C4) I started to panic, thinking I would be left behind on the dock. After several minutes of trying I just put the key in the ignition and tried to start it with me still outside. (convertible). The alarm (horn) went off. Finally after trying some more, I was able to shut it off and unlock the car. I was told that the ship's radar was probably interfering with the signal from the key fob.????
To Anyone had probs. with door locks going crazy?
