Dynaspark users, opinion needed...
I am sure it does not use a dowel pin. When I have installed other optis it can only go one way and because it is indexed I will not force it, it will just slip without effort when aligned properly.
The measurements that dynaspark suggests will tell you if anything under the timing covers is worn.If you installed the Opti right( as it appears you did) then pass the measurements it should be all good.
