Friday is the day
Old Aug 13, 2005 | 08:15 PM
Bruce's Avatar
Bruce
Default Friday is the day
Well, Friday, we are heading back to the track to make some runs again. Hopefully everything gonna holding up. We are intented to boosting 20+psi. Hopefully Rick will install the mega squirt and LC1 WBO2 feedback some time before Friday. I will be picking up 5 gallon of C16 race fuel on Monday. I want to see this car run hard as it intented to be. If Rick can borrow a set of drag radial tires from the C5 buddy we will trap them up for the track.
Bruce
Old Aug 13, 2005 | 08:47 PM
Brand-X's Avatar
Brand-X
Bruce,
You need to get some vdeo of that thing making a pass!!! Keep us informed as to the times you're laying down. Also, let me know how the WBO2 works with the C16...I've heard leaded fuels can cause those types of sensors some problems.
Chris
Old Aug 13, 2005 | 09:21 PM
Bruce's Avatar
Bruce
Chris
According to the LC1 manual. It says if using leaded fuel will shorten the life span of the sensor. It also says this sensor will last 50-500 hrs if using leaded fuel. The leaded fuel I will be using is only for track use. Therefore it should last for a while.
My factory O2 has been replaced with Denso lead resistant sensor. This sensor has been tested by GMHTP while back. So lead fuel is not a problem. We will try to get some video.
Bruce
Old Aug 14, 2005 | 12:48 AM
Brand-X's Avatar
Brand-X
Originally Posted by Bruce
Chris
Bruce
Old Aug 19, 2005 | 08:32 PM
Bruce's Avatar
Bruce
Thunder shower here today. No luck. One way or another we will hit the track at least once before they close down for the Fall.
Old Aug 19, 2005 | 09:16 PM
SLOWRIDE's Avatar
SLOWRIDE
Bummer on the rain. Good Luck
Old Sep 8, 2005 | 10:55 AM
Baldturbofreak's Avatar
Baldturbofreak
Bruce are you still plannng to take this friday off? A bunch of us are going down there you should come. Including a guy with an eclipse running 37psi! Should be fun to watch his rearend explode.
Old Sep 8, 2005 | 01:12 PM
redbullapril23's Avatar
redbullapril23
we had a guy here with the AWD talon.. haha yes a talon... running 30 psi. we pulled next to him and omg what a freakin huge front mount. raced my friend with a truboed to heck civic ... man did that thing scream! said he was putting over 400 to all 4 wheels
Old Sep 9, 2005 | 02:36 AM
zelement's Avatar
zelement
Any updates?
Old Sep 9, 2005 | 03:48 AM
Bruce's Avatar
Bruce
Originally Posted by zelement
Any updates?
Last time we could not go because of rain. But this Friday we will be at the track. Hopefully nothing will breaks at 17psi.
Old Sep 9, 2005 | 10:04 AM
Baldturbofreak
Im going to borrow the digital camcorder from my buddy james for tonight. This way we will have quality vids for my site. Call me this afternoon, bruce.
Old Sep 9, 2005 | 01:34 PM
redbullapril23
quick q for yall 2. damn im a good rapper. not
what kind of gasket are yall running on the waste gate to the flange?
my friend with the turboed civic keeps blowing gaskets. and is looking for what other turboers use.
thanks your friend
Sean
Old Sep 9, 2005 | 01:42 PM
Bruce's Avatar
Bruce
If he running a lot of boost. try arp head stud and cometics multi layer steel gasket that is what I have now. If he still getting blown head gasket that mean he running to much timing and to much boost and not enough octane or he is running to lean that caused detonation.
Old Sep 9, 2005 | 01:45 PM
redbullapril23
wait i mean on the waste gate not the head gasket.
Old Sep 9, 2005 | 03:10 PM
Bruce's Avatar
Bruce
I don't use any gasket for the wastegate
Old Sep 9, 2005 | 03:17 PM
redbullapril23
ok got ya ill pass that along. he also warped the gramet on the inside of the waste gate.
Old Sep 9, 2005 | 04:11 PM
Bruce's Avatar
Bruce
Just filling 5 gallon of C16 fuel @$9.50 a gallon. I am hoping to see high 10s tonight with street tires (no drag radial tires available) We won't be able to run more than 17psi because the secondary fuel injector s are not up running yet. I am sure the 1st set injector will absolutely maxed out at that boost level. Oh well but at least we will see what it does in the track.
To Friday is the day
Old Sep 9, 2005 | 04:47 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
Good luck, Bruce - I'm sure it'll be a blast!!! Let us know how it turns out.
Old Sep 9, 2005 | 11:11 PM
Bruce's Avatar
Bruce
a bad day. was not run great at the track. Still running way rich. I am going with stand alone next yrs so I can do my own tuning.
Old Sep 9, 2005 | 11:12 PM
lcvette's Avatar
lcvette
its 11:15.. do you know where you track tested turbo buddies are? How was it guys.. how did she run.. I'm on edge.. where did ya take it to race? california?..lol post up when ya get back.. we're waiting!
Chris
