[Pics] My Nitrous Install
I'd rather fuel get to the motor before nitrous, so it spikes rich instead of spiking lean.
I've tested time and again the fuel pressure, the entire fuel system is in 100% working order.
As for the bottle mount, it was just mounted to the cargo area. No blow-down tube, but it did have a burst disc.
Don't shrug this off as peps putting the install down or anything, they are trying to give you proven advice. We would rather see you take a step back and say "Hmmm, okay maybe I should put this on." rather then a future post of "Hmmm, engine let go, Why?"
However you go, good luck and be safe.
Right..what I meant by keeping it on the button is better for me, is because then, I won't have to go part throttle EVER, I can let off the nitrous, which will let me get traction and then hit the switch again, staying WOT the entire time...
???!!!!!! All I can say is yikes! Having no rev limiter is like having a hole in the tip of your condom IMHO... I've hit my rev limiter a few times in my days while ripping through the RPMs because I'm too busy paying attention to what the rest of the car is doing, watching the road/track, and the guy next to me. Was there ever a rev limiter in the car or did it actually not come with one? Your braver than I am I'll tell you that.As for keeping the button, I'm guessing you have an automatic. If you don't, then I can't see how you can go WOT all the way on a launch without breaking loose, hell it would still be hard even if you do have an auto.
In the end, it's totally up to you, I've passed my recommendations, so no more
for me.
Have you checked into the year 2005 lately?...such a thing called Drag Radials (or slicks, since it looks like you have the LT5 power)..try them
IIRC, Rat Racer used to be on the forum, with a 90 ZR1 on the jug, running in the 10's.
Well aware sweetchuck been running my corvette for a while now, been on the bottle for a few years too, I know alittle bit about both. Good luck with your setup, hope it stays together
www.mauidiving.com/car/nitrousblow.jpg
In reality the NX Nitrous solenoid was leaking into the plenium .
All the safety devices were installed and see what good it did!
