It sounds to me like you want the best of both worlds which really can't be accomplied on a heads / cam car. Anything you do to improve your low end is going to cost you on the high end.
The CC306 cam will make a lot of HP but it will chew up a ton of torque down low. If you don't like the low end of the hot cam you'll absolutely hate the cc306.
Yeah you wont like the 306 any better at all. If you go with SR you'll lose the very top-end, and then you can go with a 74219 cam thats made for it.
If you wanted a little of both, the only real option is the StealthRam, but it doesnt fit under stock hoods. Its not a screamer like the MR/LT1 but it should do better at top end than SR.
I will assume that you still have the 3.45 rear gears. You may be able to get what you are looking for by switching to a gear more suited to the Hotcam. 4.10's for instance may help, and you can still have high speed capability. It's just a thought.
Yes I thougt about that to...
My car starts to pull after 3500rpm and is strongest between 4000rpm and 6500rpm. Is that normal for a hotcamed lt1intake car?
