How to delay shift into 4th?
As I keep saying to myself that I like my 90 better, I think the thing that would keep me from buying an SSR (besides the $$$) is changing my tranny so it did not shift into 4th so quickly. I would say that it seems to shift into 4th at about 37 MPH. I have 3.73 rear and a MAD DOG tranny. These are not WOT shifts, just regular mild acceleration.
What controls the 700R4 shifting into 4th so soon and can a novice change it?
BTW - I was very impressed with the SSR. It moved very well and handled great too. I would buy one except the wife is going to draw and quarter me if I do. They had a yellow C6 right next to it, but I dared not take it for a test drive (me might like).
The stripped SSR was $37K, and they had one fully loaded (except for the wood kit) for $41.5. Only thing is that even the stripped one was pretty sparse. When I buy something in the 40's I expect climate control and a navigation system. Also the SSR only had dual air bags and I expected more (like side air bags). I guess Chevy is going for that all go and limited luxury segment.
I have heard of people getting these new SSR for low $30k's - which is just about what I think it is worth.
me decide to keep it is if the transmission could be altered so as not
to shift into 4th prematurely. I would say that it seems to shift into 4th
characteristics of the 700R4.
The Transgo p/n# is 7-4-VL. I don't see it on the Transgo site but
I do see a p/n# close to it here. An old post that discusses it appears at
the bottom of this '03 thread, it reads - "WITH TYPE 1 Valve Body, if you
want a later high throttle 3-4 upshift or higher speed 4-3 downshift,
install TRANSGO 7-4-VL special 3-4 shift valve."
The B&M p/n# appears to be BMM-70249 at Summit. Click on "B&M TH-700R4
Wide Open Throttle 3-4 Upshift Kits" for more info.
Edit: You have a '90, these valves may not be appropriate for post-'88
cars. If not, do some research to see whether similar parts exist for
later applications.
However, read the section about burned 3/4 clutches at the bottom
of this page entitled "Alter Shift Quality, When, and If It is Needed"
They run about $30
The TV cable controls line pressure vs. TPS
The govenor valve controls shift points vs. output shaft speed.
tweaking shift points.
Check out this link and others that come up in Google
searches on the subject.
Good post, further
From
http://www.transmissioncenter.net/subject.htm
