Carb with 4+3?
Old Aug 16, 2005 | 03:42 PM
88espo's Avatar
88espo
Default Carb with 4+3?
Can I use a carb with a 4+3 Trans and still have the OD work? If so how? Thanks as usual for all your help guys.
Old Aug 16, 2005 | 03:55 PM
CAJUN C4's Avatar
CAJUN C4
I'd bypass the ECM and use the OD with the Manual Switch only. That's what I've done. BTW..Why are you considering a Carb?
Old Aug 16, 2005 | 04:01 PM
88espo's Avatar
88espo
I had an engine rebuilt and installed. They screwed it up so bad (wiring) and engine. Now rebuilding it again and just want a easy fix. I can also build more horsepower without the cost of tpi set up. I already have manifold and carb sitting in garage.
Old Aug 16, 2005 | 04:06 PM
CAJUN C4's Avatar
CAJUN C4
You might consider an X-Ram. see www.x-ram.com I run a 375 HP ZZ4 with 22 MPG on the Road.
Old Aug 16, 2005 | 04:08 PM
88espo's Avatar
88espo
To Carb with 4+3?
