Pulled two 02 Sensor codes...
Old Aug 19, 2005 | 02:10 AM
redbullapril23's Avatar
redbullapril23
Originally Posted by TorchRedlt4man
I consider myself an expert when it comes to the C4s and the LT1s and LT4s. Until tonite, I never knew about the oxygen being carried thru the wires for the O2 sensor. I guess I should do more reading of my service manuals!
i dont consider myself but man i sure didnt know that.
i think the 2 codes im throwing are related to how cold a plug im running with the nitrous... we will see in a matter of days.
guys who are throwing the codes what plugs are you runnin?
i am running ngk B8efs. the codes werent thrwon b4 the n20 install.
Old Aug 19, 2005 | 08:53 AM
LT4BUD's Avatar
LT4BUD
[QUOTE=redbullapril23]iguys who are throwing the codes what plugs are you runnin?
I seriously doubt if a P0152 code is related to a plug issue......I had the code with both the factory OEM plugs and two different heat ranges of Denso irridiums........that is three(3) different sets of plugs in the car...
And to repeat my first post, I doubt if it is the O2 sensors as I threw the codes both with the OEM sensors and new Denso sensors, no difference.
I think the fact that I ALWAYS throw the code about 3-5 miles after a cold start is a BIG clue......but I still don't get it?????
Old Aug 19, 2005 | 06:13 PM
jerrys 1989's Avatar
jerrys 1989
how do you test an o2 sensor ?
Old Aug 19, 2005 | 06:18 PM
redbullapril23
im going to check my coil and opti for faults. good luck man
