Pulled two 02 Sensor codes...
Old Aug 17, 2005 | 11:01 AM
JEFNLSA's Avatar
JEFNLSA
Default Pulled two 02 Sensor codes...
1996 LT4
PO132 = O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
PO152 = 02 Sensor Circuit High Voltage (Bank 2 Sensor 1)
I assume by this that I need to replace two different 02 Sensors. Is that the case, or are these codes related to only one sensor? I'm guessin' two.
Where are these sensors located? (left/right-front/rear of engine)
When purchasing 02 Sensors, are the four (or is it three) on my car the same?
Anyone w/ some experience w/ this, pls. respond.
Thx,
Jeff
Old Aug 17, 2005 | 02:06 PM
bogus's Avatar
bogus
I am not sure if those are the front or rear O2s...
Logic would dictate that Sensor 1 is the lead O2, but, in the world of computers, we have an alarming tendency to start with 0!
Do you have the Helm Manual? If so, that should tell you which is which.
Old Aug 17, 2005 | 02:34 PM
CFI-EFI's Avatar
CFI-EFI
Don't shoot the messenger(s)!
Just because the O2s in both banks (that indicates two sensors) sent "Circuit High Voltage" readings, doesn't mean that both sensors failed simultaneously. What are the odds of THAT? You might suspect that the oxygen levels of both banks actually caused those readings. Sensors sense. Just because you don't like what they have to say doesn't mean they're wrong. Pull out your "hobbiest manual" (aka Helms) and start trouble shooting the REAL problem.
RACE ON!!!
Old Aug 17, 2005 | 02:51 PM
bogus's Avatar
bogus
that's what I get for posting right after I get up in the morning... missing something as obvious as what CFI-EFI said...
Old Aug 17, 2005 | 02:52 PM
JEFNLSA's Avatar
JEFNLSA
Just got my PCM back (pcmforless) and the car was throwin' the PO132 before I sent it & is still there. The PO152 is new. If it's throwin' these codes, do the sensors need to be replaced regardless?
Old Aug 17, 2005 | 02:58 PM
bogus's Avatar
bogus
No, that's what CFI-EFI is trying to tell you.
Do you have the Helm Manual? If not, get one, if so, start debugging. There is another reason for this beyond random chance that both O2s died at the same time. It is possible, but I am of a school that says debug versus throwing parts at it.
It COULD be a bad pair of O2s, but it might not, either.
Old Aug 17, 2005 | 03:16 PM
JEFNLSA's Avatar
JEFNLSA
1st off, I must sheepishly admit that I do not have a Helms. (Chiltons, but that doesn't count)
Let me get this straight...(no relation to that thread )
My 02's could be fine and my problem/s could be elsewhere. I figured if they are throwing a code, they must be replaced.
If it was running lean, rich, too much air/fuel etc..., wouldn't I be getting those types of codes?
I'm only getting those codes, any guesstimations? Like I said the PO132 has been there for a bit (was planning to fix after I got my PCM back) but the PO152 is new.
Thx for the help...
Old Aug 18, 2005 | 02:01 PM
CFI-EFI's Avatar
CFI-EFI
Let me put it in different terms. If you spot a burglar messing with your Corvette on your garage cam, what do you do? Buy a new camera???
RACE ON!!!
Old Aug 18, 2005 | 02:09 PM
CFI-EFI's Avatar
CFI-EFI
RACE ON!!!
Old Aug 18, 2005 | 02:33 PM
JEFNLSA's Avatar
JEFNLSA
RACE ON!!!
Good analogy... I get it...
Actually had it scanned by a friend last night and the 02's are reading fine, so the problem lies deeper within. I actually had someone email me all the diagnostic info relating to the 02's, so it's troubleshooting time.
Thx...
Old Aug 18, 2005 | 02:42 PM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
I loved the analogy about the burglar!
With the diagnostic information I sent you, it is just a matter of time before you find the culprit!
Good Luck!
And let us know what you find!
Gregory
Old Aug 18, 2005 | 04:13 PM
redbullapril23's Avatar
redbullapril23
the p0152 is the rear sensor. maybe both not positive.
i am throwing same code.... i have 02 sims. called casper electronics(maker of the 02 sims)... and they said that the ones i had were faulty and they would replace them.
i have a 1996 obII car as do you. you have 4 02 sensors. the front 2 adjust AFR from the exhaust(these are a must!). the rear ones are for emmissions purposes. the 02 sims go on the rear ones.
you have 4 sensors. drop the exhaust check the sensors. and replace them. buy 2 02 sensors as you are throwing 2 codes. change out old 1's with the 2 new ones and change them around to find which ones are bad. if you dont wanna do that replace them all.
if you car isnt running like crap its prob both rear sensors. if it is you could have a combo of both.
your friend
Sean
Old Aug 18, 2005 | 04:56 PM
CFI-EFI's Avatar
CFI-EFI
AMAZING!!!
Some people just don't get it.
RACE ON!!!
Old Aug 18, 2005 | 05:26 PM
JEFNLSA's Avatar
JEFNLSA
AMAZING!!!
RACE ON!!!
Well, you gotta appreciate the help (or the intent) regardless...
Old Aug 18, 2005 | 05:32 PM
LT4BUD's Avatar
LT4BUD
1996 LT4
Thx,
Jeff
That is me, with my LT4.......I got the 152 several times, then finally got a 132.........
I suspected on the advice of others that my sensors were getting lazy, so I changed all four sensors, just to be safe......DID NOT FIX THE PROBLEM!!!!!
I have noticed I always get the code around 3-5miles after startup.....probably about the time I am going closed loop.....later someone else reported this same thing on another LT4......
Many things could cause this code.....injector malfunction for example....
I have since got autotap and for sure my new sensors are not lazy
Car runs great and turns in great economy???
If someone figures it out please post.....
Old Aug 18, 2005 | 05:35 PM
bogus's Avatar
bogus
AMAZING!!!
RACE ON!!!
So they continue to spread useless and invalid data...
Old Aug 18, 2005 | 06:21 PM
TorchRedlt4man
PO152 is the front sensor on bank #2 (right side of engine).
Your engine is running too rich. Could be bad fuel pressure regulator (check for fuel in vacuum line). Could be too high fuel pressure. Rich injector. Leaking injector. EVAP canister fuel saturated. Bad MAF sensor.
All HO2S wires and connections should be inspected for breaks or contamination. HO2S wires actually carry oxygen to sensor.
The preceding is brought to you by General Motors.
1996 Y Platform
Corvette Service Manual
GMP/96-Y-2
BOOK 2 OF 2
Includes: Engine and Transmission
To Pulled two 02 Sensor codes...
Old Aug 18, 2005 | 06:29 PM
CFI-EFI's Avatar
CFI-EFI
That brings up an interesting point. The intent, that is. As you hang around longer and get to know the players, better, you will understand what I'm talking about. It took a few posts, but finally, you got it. After you did, someone else, still hadn't. Sometimes you will see gibberish responses to fairly complex questions, feigning knowledge, and then, an inquiry like, "who's buried in Grant's tomb"? from the same party. Mind boggling.
RACE ON!!!
PS. Bogus, you saved me a PM.
Old Aug 18, 2005 | 06:35 PM
CFI-EFI's Avatar
CFI-EFI
I readily admit knowing little in the way of specifics on the LT, Gen II, engines, and that I know virtually nothing about OBDII, but I'd like to hear more about this.
It's time to learn. again.
RACE ON!!!
Old Aug 18, 2005 | 07:07 PM
TorchRedlt4man
I consider myself an expert when it comes to the C4s and the LT1s and LT4s. Until tonite, I never knew about the oxygen being carried thru the wires for the O2 sensor. I guess I should do more reading of my service manuals!
