Ign Coil Module any ideas????
I will try to find that thread - it has a test!!!
Also, www.gordonkillebrew.com - he is the MAN when it comes to these cars. It ain't cheap, but I suspect he will have you running for about $20.00!!!
This does away with all the guess work.
Tom Piper
A good idea.
Lani
Lani
Four cylinders fire per revolution of the crankshaft -- so, 4 x rpm / 60 (divide minutes into seconds) = frequency in hertz.
The input signal to the ignition module (which is the output from the ECM) is going to be a "trigger" signal which will be only a spike -- I think the output of the ECM has an amplitude of 5 volts peak-to-peak.
The output from the ignition module (which is the input drive to the primary of the ignition coil) will look like a square wave with an inductive dampened oscillation (ringing) on it -- this is also the signal that is sent to the tach filter; the tach filter filters out the ringing so there is a square wave to drive the tach. This signal is about 12 volts peak-to-peak.
These signals are all common signals to any "Kettering" ignition system.
Tom Piper
Oh BTW, I have a new ECM, new coil and new ICM being overnighted.
I was just describing what my old alternator was doing, it was just making all kinds of noise and when I replaced it was so quiet you barely hear it now. I wasn't even aware of this diode thing until you posted.
Oh you betcha I will keep this going until I resolve it. If anyone ever has this condition happen to them, I would dearly pass on all information to help someone who experiences this.
That's what they call the main computer (or sometimes the ECM?). Anyway, on my 95, this is the large shiny metal box with fins on the rear of the driver's side of the engine compartment--easily accessible. On earlier years I believe this is inside the car.
I read the Alt thread too and I bet everyone who did will run out and check for AC on the alternator.
It does not matter square or sine(my bet is square) you should be able to see the signal and amplitude.It is not that hard to adjust a scope if you know what you are doing.Hope you get it straight soon but my bet right now is the ECM dc signal is low voltage.Guess you will find out shortly.
I have one on order should be here in the morning. Its being over nighted.
What was interesting which I have no explanation for: Just shortly after we stop the trace and got a couple images, the trigger signal went away. At first my friend thought he just lost the connection with the probe but we could never get it back. I looked at the temp and it was up to 158 at that point. I don't know if that means it went from one mode to another or not. Electronics is sometimes above my head. And I shut it off, then restarted just to see if it came back but it did not.
Of course I showed him how instantly it starts with the old module, then I plugged the new one in and it would not fire over.
I guess one nice thing about it all, I got a compliment on how clean my engine is, my friend was shocked when he put his hands on my engine and was so surprised his hands were still clean LOL.
Did you have the scope on when you tried the new ones and did it show a signal going to it?
You shut it off and it did not come back.What the trigger signal while it was running?
Now what did you see on both modules with the scope on input and output?
Are you sure you were reading the signal for the coil since you said" it went away"but the car still ran or am I reading this wrong.
FYI an alternator works on a rising and falling magnetic field and any wires close enough to it will get some induced AC voltage in them. 14VDC in a rectified circuit equates to around 28VAC pre-rectified.
Darn it was replying and electric went off, stupid thunderstorm.
First I wanted to say thank you to everyone for standing with me through all this, I sincerely appreciate everyone's help.
No we didn't scope the new module. Of course now I'm in territory I am clueless about with this stuff. I didn't think it would show anything since I couldn't start it with the new module. I'm a little hesitant to crank that long on it when it won't fire off. I don't need to burn up my starter or wear down my battery. I have enough problems with this beast.
I'll try to describe better, wish I had a floppy I may run back to work here its not far there are still people there I can pull the images off. But in the mean time...
I started it up, he had the probe in the white wire, terminal B, which comes from the ECM and the other white wire terminal D to the coil. The probes are really thin and sharp, so he just penetrated the wires.
I believe he had the scale for the B terminal set to 5 volts and the D terminal to 50 volts. I need to post the image so you all can see.
He was making some adjustments with the scope to get a clean reading. It was probably about 5-10 minutes I guess. Everything seemed to be looking good then as I mentioned near the end of that time period just after we got some images it just went flat. While he was checking to ensure the probe was still in there good, I looked at the temp gauge to see where it was at. It was something like 158 and climbing. But the signal would never come back. I shut it off and restarted and no it never came back. My best recollection was the square wave covered peak to peak that block for 5 volts. So it was there while running then went flat.
