I have an Auto Xray EZ Scan 3000 for OBD 1 systems. It will only scan with "key on, engine off". I tried to scan with the engine running and it will not recognize the cars ECM. You can here the idle change a little when you plug it in with the engine running. I assume the cars ECM is going into the "diagnostic" mode as soon as the connection is made. I called Auto XRay and they said their scanners do not support GM OBD 1 with the engine running, just "key on, engine off" mode. Guess I wasted some $$ on this thing. Whats puzzling is the read out I get when I scan with the engine not running. It shows data as if it were running: rpm-644, 02-408mv, 02 cross counts-36, block learn-155,BLK LRN cell-1, iac-144 steps, spark advance-19.9, knock sensor-26, inj pulse-1.70 mS, mass air flow- 23 gr/sec, rich lean flag-lean, loop status -open. Are these readings what the ECM on the car stored from the last engine run? Whatever, I need to diagnose my high N0x problem and it doesn't look like this Auto Xray unit is going to do what I had hoped( scan in real time with the engine running). Anyone else have any experience with Auto Xray on OBD 1??
Edit: Moderator-------- I think I should have posted this in "scan and tune". Any way to move it over there?
Reason: Wrong area
Mine shows running info just fine. Are you sure you don't have a mis communication with the vendor? I'm a little rough on the details, but after starting, I could either read a snapshot, or look at streaming info. I used to have problems staying connected, but that went away when I replaced my ECU.
I went online and downloaded the latest software to my PC and then did another download to the scanner with the latest "tool" software. Still doesn't work with the engine running. The guy I talked to at Auto Xray seemed like a sales type person. I could hear him in the background asking a tech about my problem. I asked him specifically if this scanner would work with the engine running and he said no ------ it did not support GM OBD 1 with the engine running. I tried several times and it will not scan with the engine running. As soon as I plug it in, the idle goes a little higher which I assume is caused by the cars ECM going into "diagnostic" mode which sets a predetermined idle speed and spark advance.
Yeah, that sounds about right. IIRC, there's a MON key that you press, after it connects, you select the rightmost button and select something like 'stream'.
I forget, I'll look into it tonight. You MAY be running into a problem where the equipment is so outta date that the folks that make it don't HAVE firsthand experience anymore.
You can tell when it's talking because the fuel calculation stuff on the dash goes away too.
The OBD-1 needs a 10k resistor between pins A & B to start the diagnostics communication.
I have a very old OBD 1 AutoXray, and a newer OBD-2 one.
I had the same problem with the newer one, checked A & B when I hit the scan button and the old one flashed 10K across A&B the newer one did not.
You might try jumpering a 10k resistor somehow (across A&B) and see if the commucation starts. I never bothered to try because I had the old one around.
Mine works - key on or running, but I have a heck of time getting it to communicate sometimes. Often I have to bend, wiggle the cable, plug it in and then unplug it and after the upteenth try, it works. I just figured that I spent so much time jamming paperclips in the Diagnostic Link that I've spread the terminals too far. Who knows - worked fine on all my other OBD 1 cars.
I can't help with the AutoXray, But high NOx is the result of excessive combution temps. Make sure your timing is set to spec and then check out the EGR valve. The purpose of the EGR is NOx emissions.
On my 1992 my AutoXray EZ scan 3000 works fine when running. I also upgraded the scanner so it now also works on OBD2.
Are you 1st hitting the scan button?
Steven
I hit the "scan" button with the engine running. After a few seconds, I get a "vehicle not responding" message. I discovered if I hit the "data" button, a menu appears with three choices; 1-operational data, 2-trouble codes, 4-EZ-PC. I chose 1(operational data) and get a message that says "initializing, please wait". After a few seconds I can see data(four lines at a time due to screen size). I can scroll down thru the list to the last item (41) which is "Loop Status". If I hit the "mon" button, the item number that is highlighted will flash and read "real time" for that individual item.
RACE ON!!!
I just installed a new EGR valve two days ago. The ports in the intake manifold were fairly clean. I checked the EGR vacuum solenoid per my Helms manual and it checked ok. I reset the timing down to 4 degrees (was at 8 degrees). Didn't change the N0x reading at all. The Hc and Co readings were well within the allowable limit. The only thing I have changed since my test two years ago was a new main cat (catco 9118). I gutted the precats due to the R/H side rattling inside.
Mine will also work if I put in another year. Make sure it is configured for your car and check the batteries in the scanner.
If it still does not work try configuring with another year. Also call Autoxray and demand to speak to someone in tech.
I'd say, that based on the above, there is little doubt where the problem lies. Even with the scanner at 100%, THIS problem won't show up on it.
I have the EZ Scan 3000, and it works fine while the car is running. It will even tell me when I turn my AC on, it will indicate if the AC clutch is off, or engaged. As my father used to tell me RTFM. Can anyone help out with the acronym?
