Wana Tune my Corvette! help!
Anyway ! i'd like to know any good ways to tune it =) ...and yeah maybe not so extremely expensive ways :p
My goal is to atleast have a chance to my sisters boyfriends car... he got an Nissan 200sx -95 with 300hp in it.
Don't stand a chance with my other car (volvo t4 245hp) =<
Wheels! i want some wheel to my "vette" to ... but i can hardy find any :< ... really nice if u cold gice me some url:s if possibly
Well it might already be some info about my question(s) but please be aware that i've just joined this "community" :p
Hope u guys could help me
1)Buy a repair manual
2) Unless you know when things have been done, consider replacing:
Brake fluid
spark plugs
sparkplug wires
air filter
oil
oil filter
hood release cable (if it is original, you should probably replace it so you know it won't break)
Clean the throttle body
Check the TPS and adjust as necessary
There is a C4 tech tip section here:
https://www.corvetteforum.com/techti....php?TopicID=2
And check the brake pads for wear.
As for the 200sx, they never released a 200sx with 300HP in the states. If it is the same little car they sold here it would be very light and have a good HP/weight ratio.
An 85' vette only has 230HP in stock form, but it does have well over 300 ft/lbs of torque which is where it's strength is.
As far as improving on power, the intake manifold is generally regarded as the weakest point in the motor, but everything from the air filter box to the intake manifold is involved as well as the stock exhaust manifolds when it comes to places for improvement. After that theres always heads and cams!
Hope this helps get you started!
Good luck!
Start with a tune up...After that the basic recipe for bringing an L98 closer to the 300HP range is, LT Headers, dual exhaust, ported plenum, larger runners, larger intake base... That should also keep your torque intact (330 ft/lbs for an '85).
I'm going by results of fellow forum members, VIC'89, 65Z01, and a few others when I recommend that.
Check the Parts section of the forum, or Ebay for different wheels. The offset on an '85 is 38MM, so if you buy 56MM offset wheels (which is what most other C4's use, you may need adapters).
http://www.motoring.co.za/index.php?...880&fSetId=381
It had this to say:
Volvo claims a top speed of 225km/h for the self-shifter that I drove and I got it up to 210 with consummate ease and rock-like stability. It also disposed of the 0-100 sprint in 8.69 sec, which is impressive for a 1300 kg vehicle with an automatic transmission.
If those number are correct for your car, then you should find that your 85' vette (in good running condition) is considerably faster than that. 0-100kph should be around 6.0 seconds flat with 400m taking somewhere in the low 14 second range. I believe the official top speed of the car in 1985 was around 150MPH or 240kph.
HTH!
spark plugs
sparkplug wires
air filter
oil
oil filter
Very good adviceDont forget the fuel filter too
I had a tuneup done last year and was amazed at how much of a performance gain it is. Cant overlook the basics
I've done everything u said now square =)... seems like the old man who had the car must have fixed most of the stuff already or most likely some workshop did it for him... anyway the car is as good as new my best investment i've ever done =)
The issue about the volvo performing that bad isn't right square
.... is does 0-100km/h on 6.9 untuned and i got it tuned from 200hp to 245hp now... so i don't think my vette will stand a chance :< I might try'em out tomorrow :p
Is it possible to order some tuningstuff from anyone from the forum here? ... seems like it's alot or atleast alittle cheaper in the states
I gotta search for some rims (wheels) to isn't the most important thing atm tho :p
Thanks again!
Thanks again!
If your Volvo did 0-100kph in 6.9 before the tune, then it would be close and I think the volvo might have an edge.
As for ordering things from forum vendors, I think it would come down to wether or not they can ship to you.
As for wheels, AFS wheels (www.afswheels.com) makes at least one style of wheels for the 84-87 corvette (the 84-87 corvette uses a different offset than the 88+ corvettes). I just put a set of their ZR-1 wheels (9.5" front, 11" rear) on last Friday. The wider rears do help put the power down from a standing start. If you are willing to use wheel spacers, then there are a lot more wheel options for you to choose from.
HTH!
I hope this does not sound like a Ostrich commercial because that is not the intent. But I do know it is compatible with various ECMs. The emulation mode with TunerPro RT is real slick. It is truely realtime.
