conventional oil
Valvoline and Mobil are also good.
I dispise Quakerstate.....
I use to work in the aviation business as a mechanic and Mobil products were used exclusivly. So I'm biased towards Mobil, thats all I use in my vehicles.
I am going to guess here... but I think that there was an old school of thought that QS was junk... it may go back to the days of coal burning cars or something.
I should retract my statement until I figure out the empirical data!
I really can't say but to this day I have never used it.
Maybe they produced a bad batch years ago and the legend lives on.
No leaks, & 36,000mi on my `87. I don`t abuse the car, but I just enjoy changing the oil & filter every 3000mi (sort of like a religious expierence
). I was using Mobil-1, but that gets pretty expensive if you are going to change oil that frequently. I know Mobil-1 dosen`t break down as quickly as conventional oil, but it does get contaminated just as quickly. I enjoy doing things with the car, & since I`m not a mechanical genius, I try to stick to things that I think I can actualy do. So far I`ve changed the valve seals, the exhaust system, right rear hub assembly
. & the transmission flush, pan & filter with my own hands. ( got the bruises, cuts, ripped skin, & blood blisters to prove it
). If it weren`t for the advice & tips of the great people on this forum, I would not have attempted half of the above projects.IMHO, along with having the car, this forum, & the knowledgeable people in it, are part & parcel of the Corvette expierience.
[IMG]
[/IMG]
www.bobistheoilguy.com
The OS Superblend and redtop oils would , based on my observation, allow sludge to build up on the heads and rocker assemblies and oil passages. Over time this would cause oil starvation on that part and could result in engine failure. QS claimed the oil lubricated better, and perhaps it did, but apparently the additive package wasn't strong enough to prevent sludge build up in the engines I observed. I know you can discuss oil chg. freq etc,, I did an actual evaluation on 2 pontiac 350 engines in 1972. Both had 3000 mile oil changes, 1 with QS SB, and the other with Havoline. At 70,000 miles the timing chains were replaced on both engines. The one with Havoline required no clean up on parts and only new gaskets. The QSSB required pressure cleaning due to build up. So,, I discontinued using QS and switched. I am sure QS has improved oil in the last 35 years or so,, so perhap this no longer applys. Perhaps this is why Dads did not use QS or Firestones. But I run my C5 on Firestones even though Dad would not be caught on them. However I use Mobile 1 in all my cars. 99 Nassau Blue,, and a dad
I was told by me salesman that on a comsumer basis dino oil is oil. I believe that this is true to an extent. I think when you are harder on a vehicle is when the differences start to show. He tried to tell me you stick the 5 top selling brands in 5 pans and cook down to nothing and analyze it, you will find less than 2% difference in what is left over. I don't know if I believe it.
IMHO....spend the money and run a synthetic. If you have a leak try Valvoline's MaxLife Full Synthetic. I run in it in my truck and Vette and love it. Truck does not leak or burn any at 160K and the leaks on the Vette have slowed down at 82K.
