'96 LT1 W/auto--Ecm editing?
Old Aug 20, 2005 | 10:06 PM
JTHVETTE's Avatar
JTHVETTE
Default '96 LT1 W/auto--Ecm editing?
I am looking for suggestions on who can do changes to the ECM OBDII.
I have a laptop computer that can be used to do this myself if needed.
I don't know what is the best bang for a dollar. I need to bypass the rear O2 sensors, change shift point for sure. I don't know if I need to make any more changes until these are done.
Please help,
JTHVETTE
Old Aug 20, 2005 | 11:30 PM
Dan Parker '96's Avatar
Dan Parker '96
Bite the bullet and buy LT1 Edit ( http://www.carputing.com )
Since you own an auto (as I do) it is invaluable for customizing shift points. In fact, tuning the engine is a piece of cake. Tuning the transmission takes about four times as much effort.
Old Aug 20, 2005 | 11:37 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
We do tuning (www.pcmforless.com)
If your interested in tuning yourself check out tunercat.com. His email is tc@tunercat.com I like tunercat much better than LT1 edit and its not vin locked on top of that.
Old Aug 21, 2005 | 01:26 AM
tjwong's Avatar
tjwong
and its a lot cheaper than Edit as well.
Old Aug 21, 2005 | 05:58 PM
Dan Parker '96
Since when did TunerCat provide an OBDII version? I'm on board if they provide one. Details please.
Old Aug 21, 2005 | 07:15 PM
STL94LT1's Avatar
STL94LT1
Originally Posted by Dan Parker '96
Details please.
Thank you for your e-mail regarding our OBDII Tuner program.
Our OBDII Tuner is now available with support for the following vehicles:
OBD2_07 1996 - 1997 Vortec Trucks (4.3L, 5.7L, 7.4L)
OBD2_06 1998 - 2000 Vortec Trucks (4.3L, 5.7L, 7.4L)
OBD2_02 1999 - 2000 LS1 Trucks (4.3L, 4.8L, 5.3L, 6.0L)
OBD2_08 1996 - 1997 Camaro/Firebird/Corvette/Impala LT1
OBD2_01 1999 - 2001 Camaro/Firebird/Corvette LS1
OBD2_03 2001 - 2002 LS1 Trucks (4.3L, 4.8L, 5.3L, 6.0L)
OBD2_04 2003 - 2005 LS1 Trucks (4.3L, 4.8L, 5.3L, 6.0L)
OBD2_05 2002 - 2003 Camaro/Firebird/Corvette LS1
OBD2_10 2004 Corvette
OBD2_12 2004 GTO
The following are scheduled for release soon:
OBD2_09 1997 - 1998 Camaro/Firebird/Corvette LS1
The OBDII Tuner package sells for $379.95 and includes the following:
OBDII Tuner Program on CD
OBDII/RS232 Interface
OBDII Cable
RS232 Cable
Your choice of one Vehicle Definition File
Additional Vehicle Definition Files can be purchased for $79.95 each.
As with all our software, the OBDII Tuner program is not VIN locked to a single vehicle.
Since we don't have the OBDII Tuner up in the web site yet, you can either order via PayPal (to tc@tunercat.com) or send a check or money order to:
C.A.T.S.
14327 Dogwood Lane
Belle Haven, VA 23306
You'll need the OBD2_08 Vehicle Definition File for your '96 Corvette.
You can download a demo version of the OBDII Tuner program at:
www.tunercat.com/obd2/obd2tnr_demo.zip
To install the demo program just unzip and run the installation program.
Best regards,
TC
Old Sep 3, 2005 | 01:56 AM
JTHVETTE's Avatar
JTHVETTE
Default '96 LT1 programming--PCMFORLESS
I just got my PCM backfrom PCMFORLESS and wanted to know what items to remove for EGR delete? This Vette is used for racing only, so don't start telling me I can't do this, please.
Thanks,
JTHVETTE
Old Sep 3, 2005 | 02:35 AM
tjwong's Avatar
tjwong
Thanks,
JTHVETTE
Pretty easy to do, just remove the EGR valve from the back of the intake manifold, and either buy or fab up your own block off plates for the EGR valve and the exhaust gas tube. You can also remove the EGR control solenoid as well.
Old Sep 3, 2005 | 07:52 AM
JTHVETTE's Avatar
JTHVETTE
Default Removing EGR ?
What about the lines that run from the back of the intake to the exhaust manifolds and the rubber hoses that are connected to these metal lines? What about the "air pump"(?) that the rubber hoses connect to? Thanks for your help.
JTHVETTE
Old Sep 10, 2005 | 02:43 AM
Mo_Bandy's Avatar
Mo_Bandy
Those are for the A.I.R. pump, you can remove and plug those as well...
Mo
Old Sep 10, 2005 | 04:44 AM
JTHVETTE's Avatar
JTHVETTE
Default EGR hoses & etc.?
[QUOTE=Mo_Bandy]Those are for the A.I.R. pump, you can remove and plug those as well...
Mo[/QUOTE
Thanks for the reply. I was pretty sure of that, I just wanted someone to conferm it.
Thank you,
JTHVETTE
To '96 LT1 W/auto--Ecm editing?
