EGR Troubles
Old Aug 20, 2005 | 10:16 PM
AFogleman's Avatar
AFogleman
Default EGR Troubles
Will an EGR code cause Sporadic idle?No vacum leaks,102,00 on an 86
Old Aug 20, 2005 | 10:27 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I would say yes
Here is some diagnostics....... http://members.shaw.ca/corvette86/Code%2032.pdf
bogus's Avatar
bogus
yup. If it's stuck open at the wrong time.
Old Aug 21, 2005 | 02:37 PM
SunCr's Avatar
SunCr
Agree that if it's stuck open, idle will be effected. However, code is thrown because the heat switch doesn't ground when EGR is commanded or it remain grounded (due to heat) after startup for longer than 4 minutes - so the code may of may not have anything to do with your idle problem. You can follow the diagnostics (and should to get rid of the code), but if it's stuck open due to exhaust deposits in the manifold, the only way to check it is to remove it.
Old Aug 21, 2005 | 04:00 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
A vacuum leak, including an EGR leak, and a dirty or faulty IAC can cause erratic idle.
To EGR Troubles
