DANA 36/44 question?
Old Aug 21, 2005 | 08:09 AM
ChopperLoco's Avatar
ChopperLoco
Default DANA 36/44 question?
Just purchased a 93 without any rear diff./suspension.Are all the dana 36/44 s the same for all C4 s?or are there some variations through the years?Thanks
Old Aug 21, 2005 | 09:56 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
All Dana36 (auto) 84-96 pumpkin and batwing same.
All Dana44 (stick) 85-96 pumpkin and batwing same.
Suspensions:
84-87 shorter, drum parking brake.
88-96 wider, caliper parking brake.
Old Aug 21, 2005 | 09:58 AM
Pete K's Avatar
Pete K
The pre 88 cars had a smaller hole where the strut rods attach. The holes sometimes need to be enlarged to fit the 88 and up holes of the strut rod brackets.
Old Aug 21, 2005 | 12:39 PM
Cory@LS2PortWorks's Avatar
Cory@LS2PortWorks
St. Jude Donor '09
yep... I was very surprised to see this first hand when I swapped my 3.07 geared batwing out of the 85 vette to my 91 vert (2.75 gears stock) it took a flashlight and 10 minutes to see the difference.. lol
Old Aug 21, 2005 | 05:22 PM
ChopperLoco
Default Thanks
Any idea how much of a width difference,and why chev did this,does it change rim offsets?Dominic
Old Aug 21, 2005 | 07:17 PM
James93LT1's Avatar
James93LT1
I think its about a 1/2 inch on each side, a total of 1 inch. With the offset, the early models (84-87)had a 36mm offset on the rims, and the newer uses the 56mm offset.
To DANA 36/44 question?
