Strange issue
Old Aug 21, 2005 | 04:35 PM
RadPolo96's Avatar
RadPolo96
Default Strange issue
Today I had the check engine light come on while I was driving. When I got home I reset the computer by disconnecting the battery. Let it sit for ten min then plugged it back in. Hoping that it was just a fluke. Drove it around some more and noticed that my fuel range was steadily increasing. It got to about 334 which is normal on full tank of gas for the car, but then it kept increasing and is now at 415. If I come to a stop sometimes it will drop to 398 but that is still way to high. What could be wrong?
Old Aug 21, 2005 | 04:39 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Nothing. A full tank of fuel should go around 400 miles at 20 MPG.
Did you check for any codes? Checking codes is the first step in troubleshooting the SES Light.
Old Aug 21, 2005 | 04:51 PM
hngacurv's Avatar
hngacurv
Mine would read into the 400 range for a bit on a full tank of gas.
Old Aug 21, 2005 | 05:00 PM
RadPolo96's Avatar
RadPolo96
Well let me post my mods just to let yah know that the gas milage shouldnt be that high. Im waitin to see if the light comes back on. Check my sig for mods.
Old Aug 21, 2005 | 10:14 PM
aboatguy's Avatar
aboatguy
Maybe you are getting good milage right now and the computer is upping the estimate. You could hammer on it a little and see if the range estimate drops
Mike
Old Aug 21, 2005 | 10:55 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Not to change the subject but I noticed in your sig that you have a LT1 Stage II intake manifold. What exactly is that? TIA...
Old Aug 22, 2005 | 12:11 AM
RadPolo96's Avatar
RadPolo96
Ported out to match stage to heads...more air flow. The milage dropped a little back down to 345. Service engine light hasnt come back but im sure it will tomorrow.
Old Aug 22, 2005 | 12:50 AM
PierEagle's Avatar
PierEagle
If SES comes back on pull code(s) and post. Neg terminal only has to be disconnected for about a minute to clear code.
To Strange issue
