Under drive question
Old Aug 21, 2005 | 07:40 PM
cjg454ss's Avatar
cjg454ss
Default Under drive question
Will any LT1 crank underdrive pulley fit my 94 corvette. i see them at summit for f-bodys but no corvette
Old Aug 21, 2005 | 09:21 PM
MaxLean's Avatar
MaxLean
Probably will not work. The majority of the LT1 F-body underdrive crank pulleys require you to stack the original pulley on top of it to maintain the original ballance and reduce costs as they can use a lower cost aluminum pulley. This works on the F-body because there is plenty of room in front of the crank. Not so on the Y-body. Underdrive pulleys for the Y-body are designed to replace the original entirely as there is no room to stack the original on top of it. That's why the 'vette underdrives are usually much more expensive. And learning is half the battle...
Old Aug 21, 2005 | 10:03 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Ask Summit for the March 1993-1996 LT-1 Corvette Power & Amp series pulley set, P/N 4425. The set consists of steel gloss black powder coated pulleys:
4141=6-rib crank pulley (underdrive)
110=6-rib alt. pulley (overdrive)
If Summit can't cross to the March numbers, give a call to March direct.
Old Aug 21, 2005 | 10:46 PM
Diesel68's Avatar
Diesel68
Default ASP Underdrive Pullies
Below is a link to ASP pullies for Corvettes. It even lists the idle speed required to achieve full charge.
http://www.aspracing.com/gm.htm#corvette
It's a direct replacement for the original crank balancer. You will have to run a shorter belt though.
Old Aug 22, 2005 | 01:10 AM
MaxLean's Avatar
MaxLean
These are the ones that I have. I'll have to disagree about their idle speed recomendations, though.
To Under drive question
