EGR removal
Old Oct 13, 2005 | 10:54 AM
tivette's Avatar
tivette
OK - I have the same issue as jjgkdg above. What solenoid are you talking about removing that gets rid of this issue?
Old Oct 13, 2005 | 11:03 AM
smacko's Avatar
smacko
Ones a switch I believe and the other's a solenoid.
I got rid of both.
Old Oct 13, 2005 | 11:54 AM
redbullapril23's Avatar
redbullapril23
first of all i dont ahve my EGR or AIr systems, i removed them.
I have a 1996 lt1 and no cats, resanator, mufflers.
it threw a code thats y i couldnt pass emmissions with lt1 edit i got the EGR and AIR codes editied out.. so all it would say was not ready. here in atlanta you can pass with 2 not readys. i had another and we couldnt figure what it was. so i just got a guy to "make it pass"
the only reason i took that stuff off was because the headers i had did not have provisions.
Old Oct 13, 2005 | 12:10 PM
Red Tornado's Avatar
Red Tornado
Originally Posted by redbullapril23
.....the function of the EGR is to keep cylinder temps higher....
on the contrary! EGR, when invoked (ie, partial throttle, up but not inlcuding WOT nor idle), REDUCES combustion temps, and by introducing exhaust gases into the combustion chamber (partial throttle) it effectively reduces the volume; smaller effective displacement means less fire, and less heat and thus lower temperatures, thereby controlling NOx emissions.
removing EGR will risk higher combustion temps, and thus "pinging" which is NOT a good thing
you should simply have ordered the correct (ie, with smog fittings) headers to begin with
Old Oct 13, 2005 | 12:20 PM
vader86's Avatar
vader86
EGR is to reduce combustion chamber temps, which reduces NOx output that results from having chamber temperatures too high.
Old Oct 13, 2005 | 01:51 PM
redbullapril23
haha yea what yall said... y do i always hear stuff back wards...
the funny thing was i just learned that in class today...
me
Old Oct 13, 2005 | 04:15 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
me
wtf did you just say?
Old Oct 13, 2005 | 04:25 PM
brookman's Avatar
brookman
The solenoid he is refering to only turns on and off the vacuum to the egr valve. When the ECM has the correct conditions to turn on the EGR valve it closes the solenoid and in turn opens the EGR valve. After a short amount of time the ECM checks the high temp switch mounted on the exhaust tube that leads to the EGR valve - if the EGR valve is told to be on and the high temp switch is not closed - you get a code 32.
Old Oct 13, 2005 | 04:27 PM
redbullapril23
i am in auto tech school, and we just learned this today. i got confused and wrote the opp.
