'91 Stereo Questions
Old Aug 22, 2005 | 10:40 PM
sremenap's Avatar
sremenap
Default '91 Stereo Questions
Has anyone replaced the Bose system with something very nice, aftermarket, fills the deck hole, and sounds good?
Let me know, i have normally had top notch systems in my toys, and the din and a half options for GM cars are lousy to say the least.
Thanks.
Old Aug 23, 2005 | 01:22 AM
bogus's Avatar
bogus
To start with, the hole is a double din...
Read this: C4 Audio FAQ
And scan through here: Audio/Electronics Forum
Old Aug 23, 2005 | 07:55 AM
mseven's Avatar
mseven
Thanks.
I agree w/ bogus on searching the audio section many have done this to their systems and this probably should be asked there.
To answer your question, there are many good doubledin sys. avail. depending on your budget. I went with a single din kenwood kdc 898 w/g force built in, mosfit amp, serius acceptable, hd radio, plays acc, mp3, cd, cdr etc. I forgot the name for the kit but it turns the empty space into a mini storage space. I also swapped out the speakers and used a plug in avail. harness for the deck swap. Good luck
Old Aug 24, 2005 | 01:24 AM
sremenap's Avatar
sremenap
well if i could move the thread i would - but that doesnt appear to be an option, and furthermore i dont even see that on the left side.
If a moderator can throw this where it should be that would be most appreciated.
Old Aug 24, 2005 | 01:25 AM
bogus's Avatar
bogus
It's not on the left side... it's under "General Corvette" on the main forums menu...
The left side menu is for C4 specific stuff only.
To '91 Stereo Questions
