Help Help, harmonic Balancer
Old Aug 24, 2005 | 12:01 AM
dlansaw's Avatar
dlansaw
Default Help Help, harmonic Balancer
Hello guys, right now as we speek I am trying to pull my harmonic balancer off. The kits offer at AutoZone do not handle a bolt this big. Does anyone have any experties on this. Thank You
Don
Old Aug 24, 2005 | 01:28 AM
quiksilver458's Avatar
quiksilver458
uhm.. The harmonic balancer is removed with a harmonic puller.. Normally go for about 15 dollars at Autozone..
Old Aug 24, 2005 | 01:52 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I got a damper puller at Sears and it uses three long bolts through the puller that screw into the three holes in the damper. Then the long center bolt simply presses against the end of the crank, through the large bolt hole in the center of the damper.
Spray the damper center with PB Blaster, snug up the three outer bolts evenly and then simply tighten down on the center bolt of the puller to pull the damper off the crank.
To Help Help, harmonic Balancer
