vortech questions
Old Aug 23, 2005 | 12:50 PM
jack the stripper's Avatar
jack the stripper
Default vortech questions
i want to switch to vortech heads and intake. im lookin at the scoggin-dickey high flow vortech TPI manifold. will i still be able to use the accel super-ram intake with this setup? another question i have is, will i still be able to use my hooker super comps with the new vortech heads?any idea how much my nearly stock l-98 will benefit from this change? thanks alot
Old Aug 23, 2005 | 03:30 PM
tjwong's Avatar
tjwong
The SR will directly bolt onto the Scoggin Dickey manifold. Also just as a note, Edelbrock also offers the same manifold now so it maybe cheaper via Summit Racing.
As for exhaust ports, any SBC header will bolt onto the heads. You should realize a decent performance gain with these heads. But, these heads have a 64cc chamber versus your stock L98 heads with a 58cc chamber. This means you will loose some effective compression by about .75 of a point of compression could negate the performance gains. If you are going to build a 383 then you can get a piston that would give you the correct compression.
Old Aug 23, 2005 | 05:37 PM
TM-Z06's Avatar
TM-Z06
Not to be **** but
Vortech = superchargers
Vortec = cylinder heads
Old Aug 23, 2005 | 06:33 PM
kopbet89c4's Avatar
kopbet89c4
Lose .75 compression points, use lower octane. I'd do it!! Especially during this season's gas prices!
Old Aug 23, 2005 | 07:49 PM
TheCorvetteKid's Avatar
TheCorvetteKid
Yeah, that through me off when I first read the title too!
I'm sure it's an honest mistake.
To vortech questions
