Hamster Powered Vette?
Old Aug 25, 2005 | 11:18 AM
96_LT1's Avatar
96_LT1
Default Hamster Powered Vette?
When I drive my Vette at any speed I get a squeaking noise coming from the passenger side front, but dissappears as soon as the brake is touched?
Old Aug 25, 2005 | 11:19 AM
TM-Z06's Avatar
TM-Z06
Sounds like the front wheel bearings may be on the way out.
Old Aug 25, 2005 | 11:29 AM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
Could also be the brakepad wear sensor.
Old Aug 25, 2005 | 12:02 PM
rickneworleansla's Avatar
rickneworleansla
Old Aug 25, 2005 | 01:33 PM
cdnguyred88's Avatar
cdnguyred88
Originally Posted by rickreeves1
Old Aug 25, 2005 | 01:36 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
That's the first thing I would check. How many miles on the brake pads?
Old Aug 25, 2005 | 05:18 PM
Diesel68's Avatar
Diesel68
I had the exact same problem with another car. Took the car to the dealership 6 times thinking it was the brakes. I got tired of taking it back and I discovered it was a front wheel bearing/hub. Replaced it and the squeeking went away. Don't rule it out as a possibility.
Old Aug 26, 2005 | 07:54 PM
96_LT1's Avatar
96_LT1
Thanks guys, this brake pad wear sensor, does it make this noise when the pads wearing out, or could it be rubbing on something? Any pics?
Thanks!
Old Aug 27, 2005 | 03:11 AM
PierEagle's Avatar
PierEagle
Thanks!
The "sensor" is a small piece of thin metal mounted on the side of the brake pad backing plate. When the pads are worn to the point that they should be replaced, the metal piece makes contact with the rotor and vibrates or "squeals". The sound may come and go or be heard all the time when the car is moving, but may stop when you push down on the brake pedal. You need to check the pads. If that is what the noise is and you let it go too long, you'll wear the pads down to the metal backing plate which will result in rotor damage.
Old Aug 27, 2005 | 03:47 PM
rickneworleansla
Old Aug 27, 2005 | 08:43 PM
96_LT1's Avatar
96_LT1
Well, Ive checked the pads, plenty of life left on them, this points to the bearing then? But if it was the bearing would the squeaking noise dissappear when the brakes are applied?
Old Aug 27, 2005 | 08:56 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
One more thing to check is the caliper does it move at all?It has an anti rattle clip/spring to the rear side that holds the caliper in place I had noise from that area and I found that to be the problem.
Old Aug 28, 2005 | 12:38 AM
parafrog's Avatar
parafrog
From: Tucson, AZ. L98-85 AUTO COUPE: 120k MILES: daily driver. SOUND OFF IF YOU'VE BEEN THERE. Ex-Jumpin' Junky-82nd Airborne-2/505 PIR: 1st ID-1/16th Inf: Recon Marine Retread. GOD BLESS GRUNTS.
i have nothing to add to this thread, but i have to tell you that the tease of a hamster powered thread pulled me right in to take a look. i don't know what you do, but you definitely have a future in advertising if you want.
frog.
To Hamster Powered Vette?
