Power Coupler
Old Aug 25, 2005 | 11:54 AM
rickneworleansla's Avatar
rickneworleansla
Default Power Coupler
Anyone replaced their power couplers for some smooth ones? What are your opinions on performance difference? It probably would'nt be much of anything but every little bit helps. Mid America sells some but they are $120 for the pair. I've heard of some people trying to do it with metal. I thought about it but it would probably look too cheesy. Was thinking of doing a temp sensor reloacte at the same time. Thanks in advance.
Old Aug 25, 2005 | 12:47 PM
gslotman's Avatar
gslotman
I have them on my 95 and there is no real difference in performance - although in theory it should aid in smoothing out the incoming air flow.
As to relocating the IAT (up closer to the air filter intake as opposed to back closer to the T/body ala the factory) - I would not do this unless you have made enough other mods to justify using the extra fuel the PCM will now be sending to your injectors (longer pulse because its reading a "cooler" air temp) via the IAT......but if you decide to do this anyway - watch your gas mileage drop accordingly.
Old Aug 25, 2005 | 03:34 PM
rickneworleansla
Default temp relocate
Thanks for the info. Im not worried too much about gas. I kinda miss the needle plunging toward empty like it does on my 67 firebird when putting it to the floor. I definitley miss the gas fumes. Gives you a much better rush when racing. Digital gauges are no fun.. My modifications are listed in my signature not sure if that helps.
Thanks again
Old Aug 25, 2005 | 03:37 PM
bogus's Avatar
bogus
WTF is a power coupler?
Is this the intake tube from the filter to the manifold?
I for one am glad cars don't smell like your 67 firebird... every so often at a track, its ok, but to have an entire cityscape effected by that stench? No thanks.
Old Aug 25, 2005 | 04:13 PM
rickneworleansla
Yep it's the tube from the airbox to the MAF sensor to the TB. As for the 67.... Well I believe it's older then the emmissions laws so there aint much you can do about it. Wear a gas mask maybe, next time you find yourself in my rearview mirror. j/jk Thanks for the input.
Old Aug 25, 2005 | 04:52 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
This is really amusing.
The purveyors of the Power Coupler (and, don't forget, the airfoil) claim that smoothing out the airflow is a sure way to increase the horsepower/mileage/throttle response of your stock Corvette.
Then, devices such as the Tornado, and those throttle bodies with the spiral grooves cut in the bores, claim that inducing turbulence in the airflow is the sure way to increase horsepower/mileage/throttle response.
Anything to get you to write them a check, eh?
Larry
code5coupe
Old Aug 25, 2005 | 05:00 PM
bogus's Avatar
bogus
I wasn't suggesting adding emissions to THAT car... no, not at all... I was just commenting that one or 2 is interesting... more then that it's annoying, smelly and makes my eyes water.
Old Aug 25, 2005 | 05:01 PM
bogus's Avatar
bogus
Larry
code5coupe
This means, you need the coupler to smooth out the air, and the tornado to induce the RIGHT kinda turbulence...
Talk about crap.
In all honesty, the turbulence, if applied at the intake port, is useful, but at the intake tube? It's a waste of $60.00+!
Old Aug 25, 2005 | 06:39 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I installed the power coupler and I felt nothing, not even an increase in gas mileage. The Tornado...yeap it took my money with it and it ended up in the trash.
Old Aug 25, 2005 | 07:47 PM
rickneworleansla
Don't think I've ever bought anything thats on an infomercial. If they need a whole hour + to convince you to buy it, it must be junk.
Old Apr 27, 2015 | 10:14 AM
exitwound's Avatar
exitwound
Its all about moving a mass of cooler air to the throttle body and into the plenum as fast as possible.
Reducing compliance or the corregations of the stock coupler will help this process just like opening the stock airfilter lid or whatever to improve airflow (speed) of cooler air.
As a medical device engineer, I understand the 'losses' in an airway patient tube due to the resistance inside (normally referred to as 'compliance') for which we have to set the life support ventilators to push harder to overcome this effect. It is real and although you may not feel a tangible difference, combined with other modifications, it will have a beneficial effect. Higher velocity is always best.
Remember the area around the air intake on an L98 is a high pressure zone so to take advantage of this and channel that air as fast and smoothly as possible. Start with a 'Big Mouth' scoop to increase that pressure which we know works as it can cool down the motor a tad..
What happens inside the plenum with that volume of air that has just arrived is a different matter to getting it there in the first place..
Old Apr 27, 2015 | 01:38 PM
BOOT77's Avatar
BOOT77
I think many people want to spend $50 on a simple mod and then blow the doors off everyone!
Turbulence makes no sense for air only and even on a carb I'd only try it after the fuel was introduced. Still even then the better way is to atomize the fuel more. The coupler is a pretty straight shot and the smoother will barely affect flow as the outer wall flow is slower anyway. I also think I read the ribs are to keep it from collapsing. Still I bought one for my TPI to test and when warmed up it does crush by hand easier than cold. I've been meaning to use my friends gopro and check for collapse with a load on a full run. I imagine the restriction before the coupler plays a part if any collapse and the level of engine modification to pull more air than stock.
Airfoil is a small diff that people will curse the heavens when it doesn't make their ride fast enough to join Torettos team. It's benefits increase with the amount of air moved, why do all aftermarket TBs come that way?
Old Apr 27, 2015 | 03:33 PM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
I bought the power coupler because my stock tube after 180K was starting to show its age, I am in the process of trying to dress up the motor and think the power coupler looks better. I have not felt any increase in performance and doubt it will ever make a difference onless its on a motor spinning some real high rpm.
Old Apr 27, 2015 | 03:44 PM
crowz's Avatar
crowz
I prefer the stock accordion type myself. Course Im more worried about motor flex vs the fixed air filter and life of the plastic parts than air flow
Also a straight tube is far more likely to collapse if there is resistance on the air filter side or from twisting while a vacuum is on it.
Old Apr 27, 2015 | 03:51 PM
eutu1984's Avatar
eutu1984
my power coupler has 3 metal rings on the inside to keep it from collapsing.
Old Apr 27, 2015 | 04:08 PM
crowz's Avatar
crowz
That should work nicely Id imagine. Most Ive seen are nothing but an oblong smooth rubber hose.
Old Apr 27, 2015 | 04:17 PM
aDigitalPhantom's Avatar
aDigitalPhantom
The smell you're talking about has nothing to do with emissions. I removed all the emissions from my 93 when I swapped the LS in, and its exhaust does not smell any different then your average car with emissions in place.
I have a 99 Malibu that is not in good shape, and its exhaust smells like that with all its emission equipment in place.
To Power Coupler
Old Apr 27, 2015 | 04:37 PM
eutu1984's Avatar
eutu1984
This is the one I have, http://www.mamotorworks.com/Corvette...upler-611195-1
Old Apr 27, 2015 | 04:40 PM
John A. Marker's Avatar
John A. Marker
Nothing like opening a 10 year old thread .
No power increase. It fits over a 52mm TB better than stock.
Old Apr 27, 2015 | 07:31 PM
Ron B C4's Avatar
Ron B C4
I got mine of Ebay for $69.00 no power gain. But looks nicer having some new rubber under the hood.
