Another window motor question
Old Aug 25, 2005 | 09:37 PM
1991 C4's Avatar
1991 C4
Cruise-In VII Veteran
St. Jude Donor '06
Default Another window motor question
I have a 1991 and the window just suddenly stopped going up or down.
I checked power at the switch and its fine. Tore the door apart and disconnected the wires from the motor and when i press the switch up or down the voltage changes from 12.5 to - 12.5 which says thats ok so i ohmed the motor but it doesn't read open it still gives me a reading of about 69 ohms. the motor doesn't click and it doesn't get warm like its binding. So I guess i'll still replace it there's only one slight problem.
How do you re-attach the motor once you take the rivets out that's holding it to the rail?
Old Aug 25, 2005 | 10:08 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When the window regulator on my '88 failed the scissor separated from the motor gear so I had to replace the entire regulator. It would have been very difficult to replace only the motor on that setup.
Is your motor riveted to a scissor or to the bottom of the window??
