Warning about Sears torque wrenches
Old Aug 28, 2005 | 06:17 PM
  #41
Ramanstud's Avatar
Ramanstud
I don't have part numbers - I bought the ones on sale for $50 (the non-digital dial-type). Used them for 2-3 years and although I haven't had their accuracy verified, I figure as long as it's precise (as opposed to accurate) then that's good enough for the odd-jobs I use them for.
Old Aug 28, 2005 | 06:19 PM
  #42
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Sears has never backed their torque wrenches. Craftsman tools are mediocre with the exception of simple hand tools, which are excellent for the price.
All their electronics are relabeled overseas junk, (their power tools probably are too.)
Old Aug 28, 2005 | 11:52 PM
  #43
pablocruise's Avatar
pablocruise
I want to bash craftsman ratchets.
I have a couple of the 3/8 drive and they get confused! They will turn one way, then lock up and turn the other way if at all. Sometimes they freewheel.
btw, I cheaped out and got a harbor freight torque wrench. A couple years and a couple motors later, I checked it against other TW's at some local shops. It was still pretty good.
Old Aug 29, 2005 | 12:05 AM
  #44
Red Tornado's Avatar
Red Tornado
geezus this all sounds pita scary. i recently bought a click-style TW from Sears, now I'm wondering if I should just throw it in the garbage!
Old Aug 29, 2005 | 10:44 AM
  #45
CentralCoaster
Their ratchets aren't as bad as I thought, yeah the gear mechanism can get confused, but they take a helluva lot of torque before they twist apart. I've broken a 1/2" ratchet, best part is, took it to sears for a new one, and bought a breaker bar... no questions asked.
Old Aug 29, 2005 | 11:57 AM
  #46
sothpaw2's Avatar
sothpaw2
Originally Posted by RichardJ
I use the old beam torque wrench exclusively. I don't trust the clickers. Never have understood or seen any advantage.
Me too. Explain the advantage. The beam is simple, there is nothing to bust or render inaccurate.
Old Aug 29, 2005 | 01:50 PM
  #47
CentralCoaster
Simply put, you can't always fit the beam type in there, it only goes on the socket 2 different ways, and you're not always in position to read it. Wouldn't be a bad idea to keep one handy though, you could look old school while wrenching, and use it to check your junk craftsman wrenches every now and then.
They also say it's very important to unload the wrench when not in use. Most of us leave that spring left at 60+ or something, that weakens it.
Old Aug 30, 2005 | 01:21 PM
  #48
GUSTO14's Avatar
GUSTO14
My first job was as a Calibration Technician in a Cal Lab. Being the new guy I had the pleasure of calibrating torque wrenches and pressure gauges for the aircraft industry. I did this for about 6 months until the next new guy checked in!!
In spite of a number of years of hands on experience with torque wrenches before this, what I learned was;
1) the bottom and top 10% of the scale is the least accurate (but not by much)
2) beam type TW's (external pointer on top) were not used - deemed too inaccurate and easy to damage
3) dial indicator TW's were some of the most accurate
4) click type TW's were a very close 2nd
(of course this was before the new electronic torque wrenches came on the scene…)
But most of all, if you treat them like a precision instrument by keeping them in their case when not in use, don't use them as a breaker bar and unload the tension on click types, they will hold their calibration for a very long time, in many cases years.
If you treat them rough, expect to need re-calibration periodically.
By the way, only Snap-On in my tool box… it's all I can afford.
GUSTO
Old Aug 30, 2005 | 01:38 PM
  #49
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
That's the one reason I've replaced all my beam TW's with clickers.
1/4", 3/8", and 1/2" so I can check everything from a few inch/ounces to several hundred foot/pounds.
And I have them calibrated every two years.
Good advice, GUSTO, to not use a TW in the high or low 10% of its range.
Larry
code5cope
Old Aug 30, 2005 | 02:12 PM
  #50
GeosFun's Avatar
GeosFun
I have not used Sears TW, but thier hand tools are excellent. I have returned 2 in my life with a "go get another off the shelf" comment each time. Sounds like the comments made here about taking care of equipment is necessary for any torque wrench instead of just leaving it at a torque setting and throwing it in the box.
I have a Snap On catalog and buy an occasional tool from them. I usually start to hyperventilate every time I look at their prices, but I think their quality is tops. Guess the moral is, if high end performance is THAT important, be prepared to step up to the plate and bend over. But don't buy 'cheap(er)' and expect the same performance (Isn't his the same rule for high performance engine parts?)
Old Aug 30, 2005 | 02:20 PM
  #51
1991Z07's Avatar
1991Z07
I had some like that...I fixed them pretty easily.
Take a snap-wring plier set and pull the retaining ring out.
Remove the ratchet mechanism and clean.
lube with a light moly grease
Reassemble
Have worked like new since.
Found a small piece of copper wire inside one of them Sometimes the bloody thing would work, other times it went dumb.
Sand, dirt & grit inside the mechanisms will make them stop working.
Old Aug 31, 2005 | 10:01 PM
  #52
96CEC4's Avatar
96CEC4
CI 4-8-9 Veteran
St. Jude Donor '07-'08
Griots garage has a lifetime testing on their torque wrenches. 3/8" is $169.00, and 1/2" is $189.00. You can find them at www.griotsgarage.com
Old Sep 1, 2005 | 03:31 AM
  #53
RichardJ's Avatar
RichardJ
Talk about an unsophisticated arrangement.
  • Spring tension
  • Friction
  • Dirt
  • dryed out grease
When you talk about accuracy, are you talking about from one bolt to the next bolt or are you talking about from one month to the next.
History lesson as told to me by my father years ago. In the early part of the last century, much of America was rural America. Many of the products and in particular, tools were purchased from the Sears catalog or at county fairs. At one such fair my father saw a man with a bare 4cyl block. 4 pistons and 4 blocks of wood. Asking the many farmers and mechanics within hearing distance to torque the head down by hand as they usually did. As each did so, the blocks were pulled out and the pistons remained in the block. The demonstrator replaced the pistons and blocks and torqued the head with a torque wrench. He pulled the blocks and all four pistons fell to the ground.
I would not guarantee my beam type torque wrenches to be accurate to any specific setting, but I guarantee every bolt on a head to be the same. There is no way I would trust that toy contraption in the drawing.
A few years ago my brother rebuilt an import engine that went bad about a month later. I was helping him on the second try, at his place with his tools and his clicker wrench. I was using his clicker to get 120lb on some bolts and I knew on the first pull it was wrong. Checking it against my beam showed it to be less than 80lb. He was so used to just pulling to the click, he never paid any attention to what his arm should have been telling him.
If you have a clicker calibrated every twelve months and find it bad, when did it go bad? Was it bad when you rebuilt that engine in the eleventh month? Was it bad when you put in the wheel hubs in the tenth month? The new ring and pinion in the seventh?
Old Sep 1, 2005 | 07:17 AM
  #54
93ZF6's Avatar
93ZF6
Default I think it will be Griot's for me
I have always gotten great service from them, re calibrations are free, and they do lifetime warrantee nearly everything they sell, I do not recall a disclaimer in their book for torque wrenches.
Old Sep 1, 2005 | 08:03 AM
  #55
joe3906's Avatar
joe3906
I read on the first page in response to Sears quality that a member made reference to an "air compressor" as an example of bad quality Sears products. I've had a Sears 3 gal. compressor for over 20 years, and the only thing I've done is change the bleeder valve that my son mangled tightening it with a wrench. I guess my then Christmas gift was one in a million. Don't own a torgue wrench, as I "suck" at being a mechanic. My .02.
Joe B.
