I got my first SES light today and checked the codes(nice write up Bogus). I got a H74 and a H32. I know the 32 is the EGR but what is the 74(LCD open)?
Now what should I be doing to get these taken care of.My first thought is to reset and see if they come back.What do you think?
H32 should be the LCD as per the factory manual. As long as the display isn't going dead or acting strange then its probably a loose connection somewhere. I have the same problem on mine so...
if this is on your 93 vette - were both codes in the 1.1 section (CCM)? then H74 is an LED open, but if you got H74 in 9.1 (ASR/ABS) it is 'low voltage'
You have to understand that the LCD displays CCM, ECM and EBCM codes.
I am assuming that the H32 is from the ECM (4.0) and the H72 is from the CCM (1.0).
Correct Bogus except H74 ,1, H32 , 4 so now what ignore it till it happens again?Geeze I don't want to start playing with the EGR I am still ironing out the tranny.
Have it your way. But just because a code was caused by one thing for someone else, doen't mean that you have the same problem. Throwing money at is is the same regardless of the method.
RACE ON!!!
PS. At least I didn't include the link, for YOU.
As alway you are right CFI I know this code has made the rounds here but the search really sucks it only goes back 2 months now wonder when Troy will address this problem.
Hmmm a really helpfull guy posted this
" The EGR isn't activated until the engine is warm, so that fits. On mine, the return spring weakened with age. The normal amount of vacuum would open the valve too far and cause a lean misfire. A good test, is to make sure it seals well when closed, then disconnect and plug the vacuum line to the EGR and see if you still have the miss."
"During heavy acceleration, the manifold vacuum drops. There is much less vacuum at advanced throttle settings than at a steady cruise. During WOT, the heaviest acceleration, the ECM blocks the vacuum (which is zero or close) from reaching the EGR valve. There is no EGR at WOT."
"The EGR valve is vacuum actuated. The wider the throttle is opened, the lower the vacuum signal available, to pull the EGR open. At WOT, the EGR blocks what is left of the vacuum, which is virtually zero, from reaching the EGR valve."
I'm happy if a previous post was helpful. I do know a little about general engine operation, but I know nothing about what causes a code 32 to set in your car. I suspect it has little to do with whether the EGR is actually opening or opening at the proper times. My car doesn't even HAVE a code 32 that it could set. Your question didn't mention a driveability problem, only that a code set, so I couldn't make a connection, there, either. Also, since I don't know what sets the code 32, (I don't have a 1993 Helms) I don't know if any of my quoted comments actually apply to fixing YOUR troubles. Good luck with it.
EFI as stated above code 32 indicates EGR and your previous post(those quotes were from YOUR previous post) was helpfull as most of your posts are.I am not familiar with the EGR operation so it was a good primer.It is good to know general operation of what your about to troubleshoot IMHO. Maybe the code was a fluke so I am waiting for it to occur again as I stated the tranny is my main concern right now and I won't have that straight till next week after I get the TV valve recalibrated. Thank you
The key here is reading the code. As what you found from CFI-EFI stated, the code will appear quick, then it's the solinoid, it failed POST... if it takes a while, then it's vacuum or valve related. It could also be a buggered up port - too much carbon.
In all honesty, from my experience, if it is the "valve", it usually is.
I had a code 32, replaced the EGR valve and it has NEVER come back. That was 4 years ago. It would come on during my drive to work... pretty much about 10 minutes after I hit the toll road.
In my case it was about 15min into a cruise and as I was turning onto a freeway ramp at low speed.Still don't get the 74 though I never had any trouble with the display and am wondering where it came from.I think it to be highly unlikely that both codes appeared at the same time and I never had an SES before this incident.Would going into diagnostic mode possibly cause this?If so I would think it should not have been a "H" code or is it possible for the 74 to appear and not turn on the SES light?
AHH I see said the blind man.So the 74 could have been there for a while.I remember geting a sys a looong time ago and pulled the neg terminal to reset it.Shouldn't that have reset the code?
