84 rear ?
Old Aug 27, 2005 | 06:39 AM
CF6873's Avatar
CF6873
Default 84 rear ?
I have found a rear out of an 84 with 3.31 gears. Will this fit in my 94 automatic and would this be a good ratio to run. I do about 3-4 track days a year and quite a bit of autocrossing and I'm looking for a little more acceleration off the corners. Thanks guys
Old Aug 27, 2005 | 11:42 AM
Casethecorvetteman's Avatar
Casethecorvetteman
I dont see any really good reason as to why it wouldnt fit yeah. The whole unit should fit in exactly as the other one comes out. If you have a 2.59:1 then that change to 3.31 would certainly make it much quicker off the line.
Old Aug 27, 2005 | 12:02 PM
CFI-EFI's Avatar
CFI-EFI
I think there may be 2 or 4 bolts, like for the camber adjustment cams, that are a different diameter and may have to be drilled out for the larger bolts. That is a driveway operation. Then after that, it's a bolt in. The whole operation is a weekend driveway project. That diff was a pretty rare find. There were only 410 cars built with the 3.31:1 gears.
RACE ON!!!
Old Aug 27, 2005 | 10:13 PM
CF6873's Avatar
CF6873
Thanks guys
Old Aug 27, 2005 | 10:37 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Originally Posted by CFI-EFI
...That diff was a pretty rare find. There were only 410 cars built with the 3.31:1 gears.
RACE ON!!!
I'll say! At one time I was thinking of swapping out my 3.07s for a set and was looking all over for them. Believe it or not, I found a source - Motive Gear actually manufacturers the 3.31 ring and pinion gears. So if you've already got a series 3 carrier, they are available. Don't know however if it would be worth the expense...
Old Aug 28, 2005 | 04:01 PM
Scott-89's Avatar
Scott-89
I would really like some new rear end gears. Mine is stock GM1 - 2.59. I would love to find a Dana 44 but don't have the funds at the moment. What are the best gears I can fit in the rear end I have ?
Old Aug 28, 2005 | 04:15 PM
CFI-EFI's Avatar
CFI-EFI
Best? Best for what? I think you can get gears as low as 3.75 or 3.73, if you consider that "best".
RACE ON!!!
Old Aug 28, 2005 | 06:22 PM
Scott-89's Avatar
Scott-89
Just for the street. I just want a little more pep when I punch it. It will barely turn over the tires now. It feels strong I just want it to be a little quicker.
Old Aug 28, 2005 | 07:17 PM
tobijohn's Avatar
tobijohn
Bench Racer
Well, you've got a two series carrier which means your only choices as far as a ring and pinion upgrade are concerned are 3.54 or 3.73. The consensus here seems to be that 3.73s are too much for L98 A4s (takes them outside the optimal power band I think is what the deal there is). And even with the 3.54s, there's the problem of breaking them although if you keep the engine stock, with an L98, you might be alright (grain of salt there as I'm no expert by any means). I didn't make a study of it but it seems to me that almost all of the broken Dana 36 w/ 3.54/3.73 gears seem to be with +300HP LT1s. Cost of parts and labor generally falls in the $700-$1000 neighborhood. Now if you want swap out the rear, there are other options....
Old Sep 6, 2005 | 10:01 PM
Scott-89's Avatar
Scott-89
Didn't realize the options were that limited. I read in another thread that 3.07 was a good choice for an Auto. I don't want to race it, and I drive conservative. I just want the pep you get from a better gear ratio.
If I ever want more than stock with the mild mods I would really want a D44 and I may go that way in the end just because its not a ton more price wise for a good upgrade and more options.
Old Sep 6, 2005 | 10:58 PM
Pete K's Avatar
Pete K
3.07 is a good option. I am a drag racer and can tell you from experience: 3.73 will make your l98 (auto)feel faster. 3.07 will make it run faster. This is drag racing situations only. I have no other racing backround. The beauty of the 3.07 ratio is you can often find complete pumpkins for as little as $100. Add free labor, fluid and new speedo gears and $150 is a real low possible number. ThIS is why I often recommend it.
Old Sep 6, 2005 | 11:02 PM
Scott-89's Avatar
Scott-89
That sounds great. Just what I am looking for. I will have to search around for some new gears/pumpkin. Thanks for the info.
Old Sep 6, 2005 | 11:06 PM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
RACE ON!!!
That sucks. We have 2 of them. That means when I break mine, I'll probably be S.O.L.
Old Sep 7, 2005 | 11:06 AM
CFI-EFI's Avatar
CFI-EFI
What are the odds of THAT??? Out of 51,547 cars sold, you have two of the 410, 3.31:1's produced. Are they both original RPO# GW4 cars?
RACE ON!!!
Old Sep 7, 2005 | 11:40 AM
Casethecorvetteman
I had a factory G92 (3.07:1) in my 87 when i had it, and it was quicker up to at least 35 MPH than my 400 BHP LT1 94 with a base 2.59. I reckon in terms of fuel economy it was just as good or slightly better if youre doing alot of town driving. 2.59:1 has only proved better on the highway and only for fuel economy,but city MPG seemed better with the 3.07:1 even with the L98.
Old Sep 7, 2005 | 06:51 PM
tobijohn's Avatar
tobijohn
Bench Racer
Nope. Motive Gear sells Dana 36 3.31 ring & pinion sets. At least according to their catalog...
Old Sep 8, 2005 | 11:42 AM
Casethecorvetteman
Who knows how much effort is it to reprogram the 94 computer to work properly with a different rear end ratio in the autos? Does the computer shift the auto based on engine revs or vehicle speed? Cause if the computer governs shifting points by speed then its not going to be a simple task is it.... But then i havent looked into this yet and have no idea what exactly the computer shifts by....
Old Oct 3, 2005 | 10:33 PM
NASCAR314's Avatar
NASCAR314
The "Hypertech Power Programmer" will do this for the 94-96's
Sometimes they be be purchased "used" in the classifieds, or, they still sell them new from all the usual Corvette Vendors as well.
To 84 rear ?
