WOT shift
Old Aug 27, 2005 | 07:43 PM
yellow dragon's Avatar
yellow dragon
Default WOT shift
i just got my 91 A4 back from having the tranny rebuilt, and now she wont shift to overdrive at full throttle, even when i hit 5500 RPM's in 3rd. did the trans shop screw up? should i get a WOT shift to OD?
thanks
Old Aug 27, 2005 | 07:49 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Just an observation on my part, I think it should. Every automatic I know eventually shifts to top/od gear. The key word is eventually. Maybe you're still in kickdown at 5500 rpm? I'll look to see what the answer(s) is.
Old Aug 27, 2005 | 08:01 PM
rodj's Avatar
rodj
Check out this further down the page http://forums.corvetteforum.com/show...48&forum_id=48
Old Aug 27, 2005 | 08:04 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
If it's a 3 speed it may not have a 4th gear.
What are you driving,Maybe its a 6 speed and you have to shift it.
Old Aug 27, 2005 | 08:22 PM
CFI-EFI's Avatar
CFI-EFI
HUH???
Corvette 700R4/4L60 transmissions are unique in that they all WOT in 4 (OD) gear. Other 700R4/4L60 transmissions, not for Corvettes will not shift to OD and/or will down shift at WOT. Your shop may just have stuffed a non-Corvette trans back into your car, or put it together from a pile generic parts. The shop owes you 4th gear up shift valve. That makes one wonder what else is missing.
RACE ON!!!
Old Aug 27, 2005 | 09:12 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
CFI, correct an impression that I have. Even tho most trans go to kickdown at wot, don't they eventually up shift into the highest gear at some point? Or, in this case, does the Corvette A4 actually stay in 3rd as long as wot is used?
Old Aug 28, 2005 | 01:47 AM
REDC4CORVETTE
My 4L60E up shifts at around 135 mph and even with a trans go shift kit in it the up shift is weak at best when it goes into high gear.
I think you car has an up shift light ,cruise in 3rd at about 65 and see if the light comes on.
I would also check the plugs on the trans .
One with 4 wire connector and a 2 wire connector,the 2 wire connector usually does not have a very long wire.
And just incase I would check the fluid,usually will effect all the gears but you never know.
Old Aug 28, 2005 | 01:48 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
No they do not. When I had the A4 in my IROC rebuilt I had the perfomance shop install the Corvette 3-4 upshift sleeve so that it would up**** into 4th at WOT.
Another possibility is that the governor is not setup right, so that the 3-4 shift point is above the max rpm of the engine. Look at the spread in the 1-2 vs 2-3 shift points to get some idea of where the 3-4 shift should occur. For example my 1-2 comes in at 5,200rpm and the 2-3 is at 5,700rpm so I would expect the 3-4 to be around 6,200rpm, as a guess.
Old Aug 28, 2005 | 02:13 AM
REDC4CORVETTE
My L98 would never see 6200 on it's best day.I would check the spring in the modulator.
Also see if the trans converter unlocks when slowing down should feel like it is freewheeling.
Or they could have forgot the check ball for 3-4 fluid transfor in the valve body.
Old Aug 28, 2005 | 12:57 PM
CFI-EFI's Avatar
CFI-EFI
The Corvette will down shift from 4th gear at WOT, but when it gets going fast enough, it will eventually up shift back into 4th. It will stay in OD at WOT. Non-Corvette transmissions will not stay in 4th at WOT. If it is in 4th when WOT is achieved, it will down shift to third. If it is in any other gear, it won't up shift past 3rd. The ability to stay in OD at WOT is a Corvette only feature.
RACE ON!!!
Old Aug 28, 2005 | 01:12 PM
CFI-EFI's Avatar
CFI-EFI
not have a very long wireOne with 4 wire connector and a 2 wire connector,the 2 wire connector usually does not have a very long wire.
That "not have a very long wire" will prevent an up shift every time???
If you find a modulator, you'd better climb out from under the car and check to see who's car it is. No C4, A4 ever came came with a modulator.
RACE ON!!!
Old Aug 28, 2005 | 06:39 PM
yellow dragon
thanks everyone, ill be having a chat with the Trans shop tomorrow morning.
Old Aug 28, 2005 | 07:12 PM
JackDidley's Avatar
JackDidley
CFI-EFI is right on target. I'd bet they used a non C 4 tranny.
Old Aug 28, 2005 | 09:41 PM
REDC4CORVETTE
Sorry not modulator but 2-4 servo
To WOT shift
