Oil Temp 250
Old Aug 29, 2005 | 10:19 PM
Rogersvette's Avatar
Rogersvette
4th Gear
Default Oil Temp 250
I have an 86 vette and live in Yuma, AZ- I am thinking of taking a trip up the coast next weekend-
For some reason, (keep in mind it is 116+ outside temp here on any given day) the oil temp is running at 250. It doesn't get a chance to get out on the hwy often-
I have just replaced the radiator and am using Mobile 1 synthetic oil--
Any suggestions of what else to do?
I don't want to take a chance being stranded somewhere--
Old Aug 29, 2005 | 10:35 PM
Pete K's Avatar
Pete K
Your case is extreme. You should add an external oil cooler. I am in a fair weather climate. External is not needed for me. 250 degrees is not terrible. Higher than I am comfortable with though.
Old Aug 29, 2005 | 10:41 PM
the blur's Avatar
the blur
nothing to worry about. your idiot light will come on at 300. enjoy it!!
Old Aug 29, 2005 | 11:02 PM
Zix's Avatar
Zix
A 250 oil temp is actually pretty normal in the AZ summer. My LT4 usually hovers around there, and so does my roommates C5. What do you have for a coolant mixture? You could always go to an 80/20 water coolant mix and throw in some Water Wetter to get down maybe 5-8 degrees in coolant temps.
Old Aug 29, 2005 | 11:08 PM
Rogersvette
4th Gear
Default oil temp 250
Zix-
Thank you for your reply-makes me feel a bit better-I am flushing the radiator now and will go to 80/20 with water wetter--thank you for your advice!
R
Old Aug 29, 2005 | 11:13 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Mobil 1 at 250 is nothingto worry about, I've been over 260 many times and no problems.
Old Aug 30, 2005 | 10:04 AM
Aardwolf's Avatar
Aardwolf
I was going to say, turn the A/C on so the fan runs, cooling the car, but at 116° outside I'm sure you had the A/C on!
Old Aug 30, 2005 | 10:43 AM
CFI-EFI's Avatar
CFI-EFI
I'll bet it cools off at speed. 250° isn't bad, even for dino. You'll be fine with synthetic. While you're playing with the cooling system, pull the top of the radiator shroud off and clean between the radiator and the condenser.
RACE ON!!!
Old Aug 30, 2005 | 12:09 PM
RIISITAS's Avatar
RIISITAS
I hit 250 degrees quite often in the Vegas area during the summer. I use Mobil 1 and I have a totally stock cooling system. No problems at all.
Old Aug 30, 2005 | 05:23 PM
Vetracr's Avatar
Vetracr
Default Maybe you should worry
Just because your oil temp gauge reads 250-260 degrees and your running Mobil 1 doesn't mean everything is O.K. Mobil 1 oil is good for 300 degrees plus before breaking down but thats not the problem. The babbit or whatever they call it now in you bearings is a tin/lead/? alloy which is approaching its melting/softening point at around 300 degrees.
The temp you measure is after the oil has been cooled in the pan and compressed by the pump. Part of the oil function is to cool the bearings. If your reading 260 out of the pump, how hot do you think it is in the bearings? Porsche racing specs oil temp not to exceed 210 and provides big oil coolers. There is a reason. FYI. I always ran the biggest oil cooler I could fit on my C4 racers. Just some food for thought.
Larry
Old Aug 30, 2005 | 05:38 PM
kpforce1's Avatar
kpforce1
Larry
Old Aug 30, 2005 | 06:33 PM
the blur's Avatar
the blur
so then GM would be warrenting 1000's of motors. why would GM have the idiot light come on at 300? and 320 on the ZO6. they obviously have it figured out, while porsche may have used lessor of a bearing material. my LT4 has seen 290's many of times.
Larry
Old Aug 30, 2005 | 07:47 PM
Zix's Avatar
Zix
Larry
I had about 95K miles on my LT4 block before I replaced it with a 383...but only because I wanted a 383, the stock block was running great. And a lot of those miles were put on in the blistering AZ summer with 250+ oil temps. The rules for Porsche engines don't necessarily apply to Corvette engines. I did change the oil a little more frequently during the summer though and used 15w-50 in the summer months, then switch to 5w-30 in the winter months.
Old Aug 30, 2005 | 08:07 PM
Vetracr's Avatar
Vetracr
Default Still not going to run 260 plus temps
My reference is from my track experience with C4 Corvettes. I can't speak for a C5 because I don't have experience with them. C4 cooling both water and oil is marginal at best. Maybe the Z06 has better cooling. If you want a real test of GM, run your Z06 at the track with 300-320 degrees oil temps and blow an engine. See what happens when you bring it in for warranty. When GM checks the black box and looks at the history before the engine blew. LOL, LOL, LOL.
Larry
Old Aug 30, 2005 | 08:46 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Larry
Vetracr, you seem to have a lot of knowledge and racing history at hand. Can you elaborate a bit more on where you've gained this knowledge, where you've raced, what type of cars, maybe even a name and location?
What you seem to be saying, correct me if I'm wrong, is that the Corvette or C4 Corvette, sold in very warm climates (Arizona, Cal. desert/San Joaquin, Texas, etc.), is ok to run, maybe a bit hot oil, but still ok. Under sustained racing conditions (key word: sustained), the tolerances are too close for engine survival. Is that right?
Old Aug 30, 2005 | 09:14 PM
the blur's Avatar
the blur
every LS6 motor is run at WOT for 20minutes before leaving the factory. the LS6 chief engineer said they NEVER blow up. The motor is designed for 300-320 oil temps. at 321 the oil temp message is displayed. and don't you think they have a saftey margin!! I have never heard of 1 failure , ls6 or lt1 or lt4 due to oil temps.
I have heard of plenty of failures due to oil starvation, but never high temps. and I track my LT4 frequently. all bone STOCK. about 5000 hard track miles to date. and I'll get another 400 miles by the end of this season.
Larry
Old Aug 30, 2005 | 10:27 PM
Zix's Avatar
Zix
I would completely agree with that statement, sustained racing in the AZ summer will destroy and LT based engine pretty quickly. 250 oil temps are fine, 300+ oil temps are not!
To Oil Temp 250
Old Aug 30, 2005 | 11:02 PM
RIISITAS's Avatar
RIISITAS
I find it hard in my area not to get oil temps of 250 degrees when you're driving around in stop and go traffic or on the highway at 110 to 120 degrees + out here in the desert Southwest. When it's 90 degrees I don't get such high oil temps, but over 110 degrees it does happen.
Old Aug 31, 2005 | 12:32 AM
Hotred94's Avatar
Hotred94
I live where it is hot, not serious like Yuma, not for long periods like LV, but I bought an oil bypass for $5, a thermostat for $20, and I've had an oil cooler sitting in the garage for years; so why not? $25 for a little peace of mind.
Old Aug 31, 2005 | 01:35 PM
No Go's Avatar
No Go
Couple of comments...
The older Porsches were air and oil cooled-one reason why the large oil cooling capability...they used it to keep the engine cool...new ones are of course liquid cooled...
I've run 300 degree oil temps for many events with a stock LT4 and current 381 ci engine...no problems. I don't like it, but still not quite ready to install an oil cooler.
If you are cruising on the highway at normal speeds and seeing 250 degrees, then I would say that is the highest I've heard for that operation...if you were pushing 100+ mph then no problem, but 250 is high...Might check the temperature sender...how is the coolant? I would expect coolant to be quite high as well...they tend to effect one another a bit...I run 300 degree oil temps and I will see 220 coolant temps...I think most would be in the same boat. Ie not a 180 coolant and 300 oil, etc.
