Brake question.
Old Aug 30, 2005 | 04:27 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default Brake question.
I have a question about brakes. I just replaced my rotors and painted the brake calipers. In the process I disconnected my calipers from the brake lines. I put everything back as designed including the washers on both sides of the bolts.
When I put everything back togethers, I started bleeding the brakes with my mityvac. I have run at least four containers of break fluid through the systme but I am still getting bubbles. I have tightened all bleeders and double checked eveything. I don't have any line leaks and no puddles under the car. I have kept the master cylinder full of fluid. The front passenger side seems to be the worst. Any suggestions?
Old Aug 30, 2005 | 05:02 PM
Vetracr's Avatar
Vetracr
Default How are you bleeding the brakes?
If your using a Mity Vac to bleed the brakes, you may be sucking air past the bleeder threads.
Old Aug 30, 2005 | 05:11 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default could be...
Very possible. The brake pedal is firm with no fade. I have pushed alot of fluid through it. I was thinking of replacing more parts but that may be it.
65Z01's Avatar
65Z01
Cruise-In II Veteran
Put a section of hose from a bleeder into a jar of brake fluid and crack open the bleeder.
Then you can pump the brake pedal without worrying about pulling in air and you can see when bubbles stop comming out. Keeping positive pressure on the system will not allow air to be drawn in past the bleeder threads.
Old Aug 30, 2005 | 05:19 PM
Square's Avatar
Square
When I use my vacuum bleeder, I always get a line of small bubbles. I read int he manual that it was air being drawn in at the bleeder screw to vacuum hose connection and not too worry about it. If I get the wife to push the pedal, I don't see those bubbles.
Old Aug 30, 2005 | 05:37 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default Is the hose full of fluid?
I can't seem to get the hose to fill completely with fluid, so to speak. I have fluid flowing but not enough to fill the line
Old Aug 30, 2005 | 06:02 PM
Steel Blue 91's Avatar
Steel Blue 91
Did you re-use the crush washers where the line bolts to the caliper? That might be the problem since they were designed for single use.
Old Aug 30, 2005 | 11:30 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default Update
It was the mity vac. I used Square's suggestion and did a manual bleed and no bubbles. Took it out for a test drive and it works like a charm... Thanks guys! The forum is one great place!!!
Steel blue 91 that is one beautiful car. Absolutely beautiful.
Old Aug 31, 2005 | 07:01 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I agree
Very important! crush washers are a single use component, if you find yourself losing a little fluid at a time, replace them and rebleed!
I prefer gravity bleed to all other methods...may take a little longer but it is virtually 100% fool proof
seeya
Old Aug 31, 2005 | 09:15 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Use teflon tape on your bleeder threads, if that doesn't work, replace the crush washers and buy speedbleeders while you're at it.
Positive pressure (pedal pumping) bleeding is always a more thorough method. There's even a phoenix tool that forces fluid into the system through the caliper (also positive pressure).
To Brake question.
