Hi Guys. Just wondering if this will work for a procharger install on my 94 LT1. The procharger removes the pcv valve and routes it to the air cleaner which allows oil to enter into the intake system. Would this eliminate that?
COOL!!!!! THANKS MO! HEY MO, DO YOU HAVE ANY FLASH TUNING UNDER YOUR BELT? IM TRYING TO LEARN ALL I CAN ON HOW TO CHANGE MY LONG TERM FUEL TRIM FROM 108 TO 128 DID YOU NEED TO TURN YOURS AFTER SUPERCHARGER WAS INSTALLED? THANKS AGAIN MO.
Hi MrNuke, Never thought about using the PCV valve on the L98 but there's no reason it won't work other than cost vs. an in-line checkvalve. The LT1/LT4 just doesn't have the room for an in-line checkvalve if you want to do neatly without a lot of extra hose - which is why I made the valve. Regards, Greg
Hmm... Would certainly look nicer than the stock pcv valve..I'll have to call you (greg) one of these days to see if it will fit and talk about some other stuff too anyways..
