Can anyone tell me what the 1995 ECM (computer tray) connects to underneath? It looks like from exploded view that tray connects to bracket which is attached to car with same bolts that hold in master cylinder??
The tray is connected to the frame work via a 10mm headed bolt to the hood latch fram under the tray. It is very simple to remove. Just look under the hood latch frame right above the battery, there is a 10mm headed bolt there that has a bracket that attaches to the PCM tray. It is in now way connected to the master cylinder.
tjwong, is there any way you can send me a picture or illustration you may have? Ive been trying to figure this out for two weeks. I see where the corner of ECM tray (plastic hole) has bolt going through it with washer and is connected right where hood pin latches..but the slot that is in the middle of bottom of ECM tray is empty on mine. Is this where you say bracket slides into it and attaches to frame?? I have even been to dealer and looked at illustration myself...it is so unclear. There was a part I ordered called "ECM Bracket" but it looked like it was held on by same two bolts that go through master cylinder. Even parts guy thought so too. I also looked at 96 model and it was impossible to tell without taking it all apart and that was not an option. My ECM is currently just zip tied.....
Under the middle of the plastic tray there is a slot where a pin does slid through it. Maybe it is that bracket that he is refering to. I will look at mine and let you know. I am not home at the moment but I can't send a picture as my GF has my digital camera.
Yes, I need to know what that pin is attached to on the car. Im assuming it's attached somewhere on sub-frame. Pic would be huge help...manual doesn't even show it. Thanks tjwong.
