Need a refresher on how to pull codes.
Old Aug 31, 2005 | 09:56 AM
Kizmo's Avatar
Kizmo
Default Need a refresher on how to pull codes.
It's been somtime since I've had to pull codes, and I've forgotten how to do it. Thanks!
Old Aug 31, 2005 | 10:06 AM
SupaVette's Avatar
SupaVette
What year do you have? if it's pre '93, just short out the aldl top right pin with the pin next to it on the left. and it'll flash the codes
If it's later model, you can short the 4th pin from the left in the top row, with the one just below it (i think it was the 4th can't remember to well) and you can go through the codes on your speedo using the eng/met buttons
Old Aug 31, 2005 | 10:08 AM
rick lambert's Avatar
rick lambert
Above the drivers knee-you short pins A & B on the ALDL, there the top two right hand side pins, turn on ignition-BUT-DO NOT START ENGINE I use a paper clip. In a moment your check engine light (on early c4) or SYS light on later c4s will start to flash. code 12 first, a single flash followed by a double flash-should repeat 3 times
after that you will either get an error code or another string of 12s
meaning no error codes.
Old Aug 31, 2005 | 10:11 AM
Kizmo's Avatar
Kizmo
I guess it would of helped to include stats. 95 LT1 auto. Thanks.
Old Aug 31, 2005 | 11:35 AM
Red Dwarf's Avatar
Red Dwarf
c4vettes.com
Old Aug 31, 2005 | 08:37 PM
Kinkajou's Avatar
Kinkajou
On Vettes using OBD1 with a 16 pin DLC connector you should short # 12 ( ccm diagnostic enable) to # 4 or 5 ( both are ground)
By the way the top row starts with # 1 at the left side ( drivers side )
Second row starts with # 9 ( drivers side ) . Just so you have it right.
I have a 94 Vette and done this a lot of times. Hope your Vette has the same conector and OBD1. If you have OBD2 you will need a scanner.
Old Aug 31, 2005 | 10:03 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
95 is OBDII
Old Sep 1, 2005 | 08:59 AM
Corf's Avatar
Corf
Originally Posted by Redeasysport
95 is OBDII
I know you meant 95 is OBDII connector with OBDI computer
Old Sep 1, 2005 | 10:54 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
95 is OBDII
95 is OBD1
Old Sep 1, 2005 | 12:23 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
AutoZone has free code reader keys. I keep one in my console to check my codes after the SES light appears.
Old Sep 1, 2005 | 05:18 PM
Kinkajou's Avatar
Kinkajou
The 16 pin ADL connector is OBD2
But it still runs on OBD1 software.
If it is like that you can retrieve the codes this way.
Old Sep 1, 2005 | 07:28 PM
bogus's Avatar
bogus
Lets make some sense of all this ODBI and ODBII stuff!
1984 to 1994 are OBDI, essentially. I don't remmeber when the term OBD was first used... but that's close enough for government work.
1995 is what I call ODBI.V! It's 1.5! OBDI computer, an extra set of dummy O2s and an OBDII connector.
1996 is full OBDII compliant.
Old Sep 1, 2005 | 07:37 PM
FD2BLK's Avatar
FD2BLK
Close but 94/95 are thae same and both have the extra rear O2 and OBDII conecttor. Both 94/95 can pull codes by shorting pin 4 to 12, the codes will display on the center dash LCD.
Old Sep 2, 2005 | 07:59 AM
runner140*'s Avatar
runner140*
95 is OBDII
1995's use a OBD11 but are not fully active----1996, also is a OBD11 and is fully active(readable with a code reader).
To Need a refresher on how to pull codes.
