2 Problems -- HELP!
Old Aug 31, 2005 | 05:12 PM
dlsmith's Avatar
dlsmith
8th Gear
Default 2 Problems -- HELP!
I recently replaced the water pump in my 85 C4. I now have 2 problems that I don't think should be related to the replacement.
The first problem is that the engine won't rev up. It starts fine, but when I try to rev it up, it bogs down and won't rev above about 1500 RPMs. I replaced the Throttle Positioning Sensor but no change.
The second problem is that the battery runs down after about 3 days. I took the battery out and had it checked. It was a fairly new battery, but it had a dead cell. I replaced the battery with a new one. Same problem. It runs downs after a few days.
What did I screw up when I replaced the water pump?
Thanks!
Old Aug 31, 2005 | 05:15 PM
dock351's Avatar
dock351
St. Jude Donor '06
the belt on right?
Old Aug 31, 2005 | 05:18 PM
dlsmith's Avatar
dlsmith
8th Gear
I'm 90% sure it on right. I'll check when I get home. If it's not on right, what would cause it to bog down?
Old Aug 31, 2005 | 05:47 PM
dock351's Avatar
dock351
St. Jude Donor '06
Just an idea. It is one thing you took off for the water pump change. Slippage on the belt might explain the alternator not working well to recharge the battery. notice any increase in engine temp?
Old Aug 31, 2005 | 05:51 PM
dlsmith's Avatar
dlsmith
8th Gear
I haven't run it long enough to notice any temperatue problems. The battery runs down just sitting. It almost like there is a light on that is running it down. I can't find any lights on though.
Thanks!
Old Aug 31, 2005 | 07:02 PM
Pete K's Avatar
Pete K
Look closely at the mass air flow sensor and it's connector.
To 2 Problems -- HELP!
