Sidesteppin
Old Sep 2, 2005 | 12:11 AM
Ibuyvettes's Avatar
Ibuyvettes
Default Sidesteppin
Picked up an 87 vert. When you give it gas, or let off the gas the rear seams to kick to the side a little. Any ideas?
Old Sep 2, 2005 | 12:18 AM
cv67's Avatar
cv67
St. Jude Donor '05
Have the alignment on all 4 wheels checked.
Old Sep 2, 2005 | 01:31 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Is it modded?
Either way, ZFDoc's C-Beam plates are made to correct this kick out. It has to do with the torque on the C-beam (the brace that encloses the driveshaft and runs tranny to diff). Though those will do a better job correcting them. The quick check to see if it is part of the issue, is to get under the car and tighten them. This may just help!
Old Sep 2, 2005 | 09:13 AM
Ibuyvettes's Avatar
Ibuyvettes
It is stock, I will get under it today to check. Also I have had alot of corvettes in need of alignment, and none have done this.
Old Sep 2, 2005 | 09:45 AM
Dynabob's Avatar
Dynabob
From: What do I know anyway? I'm just a 50 year old No0b
My old '68 Chevelle used to do that. The bushings in the rear end components were totally shot letting the rear end move around. Check all of your mounts and bushings.
Old Sep 2, 2005 | 09:53 AM
chucks88's Avatar
chucks88
I'm thinkin' bushings too. How many miles on the car. You may find that your convertible(like mine) needs every little bit of help it can get in an effort to tighten up the chase. Beam plates, bushings and camberbrace all had a possitive impact on my ride.
Old Sep 2, 2005 | 08:48 PM
onetrackmind's Avatar
onetrackmind
REAR BUSHINGS
Old Sep 2, 2005 | 10:43 PM
Pete K's Avatar
Pete K
Check the rear tie rod assembly from end to end. These were comon trouble spots in the earlier c4 years.
To Sidesteppin
